Seen that GPU[gk20a] is under run time power management. Code is located: drivers/gpu/nvgpu/gk20a/gk20a.c
Could you please let me know about
what cases / events GPU[gk20a] will be powered on in Jetson tk1,
what is the condition & status GPU[gk20a] will be powered down in Jetson tk1.
Using the following command to know status of GPU[gk20a] power on / off status:
cat /sys/kernel/debug/powergate
Thank you very much
Do you have HDMI attached? You might find these wiki pages useful:
[url]Jetson/Jetson TK1 Power - eLinux.org
[url]Jetson/Performance - eLinux.org
Thanks for information, which I have already gone through it.
My request in the question is
You could refer to TRM description about GPU PLL and GPU power gating. In general, the software you develop should not worry about power on/off GPU. What you would concern is generally system power of the device under certain use case.
