I’m a newbie here with GStreamer, running a Jetson Orin Nano (4GB) with Jetpack 5.1.1 and GStreamer version 1.16.3. I can run this pipeline up to 60 fps without problems:
gst-launch-1.0 videotestsrc ! video/x-raw,width=800,height=800,format=YUY2,framerate=60/1 ! videoconvert ! video/x-raw,format=RGB ! queue ! ccm800x800cv ! queue ! videoconvert ! queue ! fpsdisplaysink
where ccm800x800cv is a custom plugin we’re developing that inputs and outputs RGB. I wanted to experiment with using Nvidia plug-ins to accelerate the format conversion from YUY2 to RGB. Following suggestions in this forum, I tried this next pipeline. It works up to 70 fps:
gst-launch-1.0 videotestsrc ! video/x-raw,width=800,height=800,format=YUY2,framerate=70/1 ! nvvidconv ! "video/x-raw(memory:NVMM),format=RGBA" ! nvvidconv ! videoconvert ! video/x-raw,format=RGB ! queue ! ccm800x800cv ! queue ! videoconvert ! queue ! fpsdisplaysink
My questions:
- Is that all the acceleration I should expect (60 fps to 70 fps)?
- Do I really need the 2nd nvvidconv plugin? Seems like a lot of steps…
- Is there a more optimal sequence of plugins I should be using?
When I push the framerate higher, I get dropped frames and output like:
gst-launch-1.0 videotestsrc ! video/x-raw,width=800,height=800,format=YUY2,framerate=80/1 ! nvvidconv ! "video/x-raw(memory:NVMM),format=RGBA" ! nvvidconv ! videoconvert ! video/x-raw,format=RGB ! queue ! ccm800x800cv ! queue ! videoconvert ! queue ! fpsdisplaysink
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
WARNING: from element /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage: A lot of buffers are being dropped.
Additional debug info:
gstbasesink.c(3003): gst_base_sink_is_too_late (): /GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage:
There may be a timestamping problem, or this computer is too slow.
Adding the -v option for more info (sorry, this gets long):
gst-launch-1.0 -v videotestsrc ! video/x-raw,width=800,height=800,format=YUY2,framerate=80/1 ! nvvidconv ! "video/x-raw(memory:NVMM),format=RGBA" ! nvvidconv ! videoconvert ! video/x-raw,format=RGB ! queue ! ccm800x800cv ! queue ! videoconvert ! queue ! fpsdisplaysink
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage: sync = true
/GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)YUY2, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstCapsFilter:capsfilter2.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstQueue:queue0.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/gstccm800x800cv+CCM800x800CV:gstccm800x800cv+ccm800x800cv0.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstQueue:queue1.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/gstccm800x800cv+CCM800x800CV:gstccm800x800cv+ccm800x800cv0.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstVideoConvert:videoconvert1.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstQueue:queue2.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:src: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink.GstProxyPad:proxypad1: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink/GstXvImageSink:fps-display-video_sink-actual-sink-xvimage.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstAutoVideoSink:fps-display-video_sink.GstGhostPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay.GstPad:video_sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)YUY2
/GstPipeline:pipeline0/GstVideoConvert:videoconvert1.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGB
/GstPipeline:pipeline0/GstVideoConvert:videoconvert0.GstPad:sink: caps = video/x-raw, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/Gstnvvconv:nvvconv1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive, format=(string)RGBA
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)YUY2, width=(int)800, height=(int)800, framerate=(fraction)80/1, multiview-mode=(string)mono, pixel-aspect-ratio=(fraction)1/1, interlace-mode=(string)progressive
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 18, dropped: 7, fps: 35.80, drop rate: 13.92
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 18, dropped: 7, fps: 35.80, drop rate: 13.92
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 38, dropped: 9, fps: 38.64, drop rate: 3.86
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 38, dropped: 9, fps: 38.64, drop rate: 3.86
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 39, dropped: 28, fps: 2.00, drop rate: 37.97
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 39, dropped: 28, fps: 2.00, drop rate: 37.97
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 54, dropped: 34, fps: 28.60, drop rate: 11.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 54, dropped: 34, fps: 28.60, drop rate: 11.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstTextOverlay:fps-display-text-overlay: text = rendered: 64, dropped: 45, fps: 19.09, drop rate: 21.00
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 64, dropped: 45, fps: 19.09, drop rate: 21.00
Note: the videotestsrc is emulating a v4l2src camera that’s limited to YUY2.
