• Hardware Platform (2x L4)
• DeepStream Version 6.2
• NVIDIA GPU Driver Version (525.125.06)
| NVIDIA-SMI 525.125.06 Driver Version: 525.125.06 CUDA Version: 12.0 |
| | | MIG M. |
| 0 NVIDIA L4 Off | 00000000:4B:00.0 Off | 0 |
| N/A 65C P0 52W / 72W | 22451MiB / 23034MiB | 65% Default |
| | | N/A |
| 1 NVIDIA L4 Off | 00000000:98:00.0 Off | 0 |
| N/A 61C P0 51W / 72W | 22451MiB / 23034MiB | 72% Default |
| | | N/A |
• Issue Type (questions)
• How to reproduce the issue:
docker run --runtime=nvidia --env GST_DEBUG=2 --rm -it nvcr.io/nvidia/deepstream:6.2-samples gst-launch-1.0 videotestsrc is-live=true ! nvvideoconvert gpu-id=1 ! m.sink_0 nvstreammux name=m width=1920 height=1080 batch-size=1 gpu-id=1 ! nvtracker gpu-id=1 ll-lib-file="/opt/nvidia/deepstream/deepstream/lib/libnvds_nvmultiobjecttracker.so" ! nvv4l2h264enc gpu-id=1 ! fakesink
Hi everyone! We have a dual-GPU setup (2x L4 GPUs) and the goal is to choose the GPU on which to run the pipeline based on our internal logic. In the above pipeline, I set gpu-id=1
for each element, but I see that some memory is still allocated on GPU0:
| Processes: |
| ID ID Usage |
| 0 N/A N/A 3139056 C gst-launch-1.0 194MiB |
| 1 N/A N/A 3139056 C gst-launch-1.0 262MiB |
But if I change DS image version to 6.3 (nvcr.io/nvidia/deepstream:6.3-samples
), the issue disappears:
| Processes: |
| ID ID Usage |
| 1 N/A N/A 3139263 C gst-launch-1.0 280MiB |
There were no mentions of this bug being fixed in 6.3 release notes, so the question is whether it was fixed or the bug still there and may happen again under different conditions? Your confirmation is important because moving from DS6.2 to DS6.3 is quite expensive for us as it requires a lot of testing, so we don’t want to migrate if the bug wasn’t fixed.
