GPU issues while invoking DW-graph-UI in docker
Software Version
DRIVE OS 6.0.8.1
[*] DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] DRIVE AGX Orin Developer Kit (not sure its number)
other
SDK Manager Version
1.9.3.10904
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with DRIVE OS Docker Containers
other
We are trying to run ./dw-graph-ui.bash in the docker and it is not working in it. we are seeing that it is detecting the intel GPU but we do have NVIDIA RTX - 3060 in it. Can you please guide us how to solve this error.
Dear @prit.shah,
Can you test it on DRIVE OS 6.0.8.1 docker?
Firstly, could you check running :/usr/local/cuda-11.4/samples/1_Utilities/deviceQuery to see if it runs without any issue.
Please share the used command to launch the docker container? See if DriveWorks SDK Reference: Getting Started Using the NVIDIA DRIVE OS NGC Docker Container helps?
Yes, it is working in the 6.0.8.1 docker.
Firstly, could you check running :/usr/local/cuda-11.4/samples/1_Utilities/deviceQuery to see if it runs without any issue. We have checked running this code in Drive OS 6.0.6 and its working (RESULT = PASS)
Please share the used command to launch the docker container? docker run -it -v /dev/bus/usb:/dev/bus/usb
-v /tmp/.X11-unix:/tmp/.X11-unix -e DISPLAY --gpus=all --privileged
–net=host \ nvcr.io/drive/driveos-sdk/drive-agx-orin-linux-aarch64-sdk-build-x86:latest (Samples Compilation From Source)
Additional Question: We have installed docker offline and dw-graph-ui is working offline , will that be okay if we work offline(not from docker) ?
Dear @prit.shah,
That’s ok. It generates Json files. We can mount(using -v option with docker) the json files back to docker to generate the c++ stubs.
Thanks for the information.
We have already installed driveworks content of docker, so that we can use it offline. Even we are converting JSON files to C++ stubs offline and it is working fine.
Also the mounting part which you mentioned in the previous reply (-v), can you please provide us an example on basis of that for the understanding purpose?
add -v /path/to/host/folder:/home/nvidia above command. Here /path/to/host/folder gets mapped to /home/nvidia on docker.
