Hi team,
I was able to bring up the customized Ubuntu Linux on the orion jetson and most of the components work well. However, I met a problem on GPU/CUDA part while running a basic CUDA program that works in native L4T os. Can experts from Nvidia or anyone else in the forum in the forum shade me some lights on this problem?
There are multiple errors. It seems the key is the falcon (flcn) ucode boot failure. Any suggestions will be appreciated. thanks
tester@tester-desktop:~/cuda$ ./vector_add
[ 31.358869] nvgpu: 17000000.ga10b nvgpu_acr_wait_for_completion:143 [ERR] flcn-1: HS ucode boot failed, err 5
[ 31.359253] nvgpu: 17000000.ga10b nvgpu_acr_wait_for_completion:145 [ERR] flcn-1: Mailbox-1 : 0x0
[ 31.359547] nvgpu: 17000000.ga10b nvgpu_cic_mon_report_err_safety_services:92 [ERR] Error reporting is not supported in this platform
[ 31.359920] nvgpu: 17000000.ga10b nvgpu_pmu_report_bar0_pri_err_status:41 [ERR] PMU falcon bar0 timeout. status(0x0), error_type(0xc)
[ 31.360296] nvgpu: 17000000.ga10b ga10b_bootstrap_hs_acr:72 [ERR] ACR bootstrap failed
[ 31.360583] nvgpu: 17000000.ga10b nvgpu_acr_bootstrap_hs_acr:85 [ERR] ACR bootstrap failed
[ 31.360848] nvgpu: 17000000.ga10b nvgpu_acr_construct_execute:108 [ERR] Bootstrap HS ACR failed
[ 31.361113] nvgpu: 17000000.ga10b nvgpu_finalize_poweron:1010 [ERR] Failed initialization for: g->ops.acr.acr_construct_execute
[ 31.391999] nvgpu: 17000000.ga10b gk20a_power_write:127 [ERR] power_node_write failed at busy
libnvrm_gpu.so: NvRmGpuLibOpen failed, error=14
vector_add.work_on_nvidia_release: vector_add.cu:49: int main(): Assertion `fabs(out[i] - a[i] - b[i]) < MAX_ERR' failed.
Aborted (core dumped)
