GPU Operator helm chat deployment issues
I am trying to deploy the GPU operator but the deployment fails with pods unable to pull images. I even tried specific versions instead of latest and I am facing the same issue.
kubectl get pods -n gpu-operator
NAME                                                              READY   STATUS             RESTARTS        AGE
gpu-feature-discovery-wdv4c                                       0/1     Init:0/1           0               2m31s
gpu-operator-1761617510-node-feature-discovery-gc-595bfd845zwph   1/1     Running            1 (3m21s ago)   3d13h
gpu-operator-1761617510-node-feature-discovery-master-59d8shxxv   1/1     Running            1 (3m21s ago)   3d13h
gpu-operator-1761617510-node-feature-discovery-worker-rsh7v       1/1     Running            1 (3m21s ago)   3d13h
gpu-operator-5c5f48f846-h9w6c                                     1/1     Running            1 (3m21s ago)   3d13h
nvidia-container-toolkit-daemonset-2rsjb                          0/1     Init:0/1           0               2m31s
nvidia-dcgm-exporter-n2m99                                        0/1     Init:0/1           0               2m31s
nvidia-device-plugin-daemonset-dxjdm                              0/1     Init:0/1           0               2m31s
nvidia-driver-daemonset-zmst7                                     0/1     ImagePullBackOff   0               3d13h
nvidia-operator-validator-sk5lm                                   0/1     Init:0/4           0               2m31s
> kubectl describe pod nvidia-driver-daemonset-zmst7 -n gpu-operator
  Normal   Pulling         3m36s (x4 over 4m56s)   kubelet            Pulling image "nvcr.io/nvidia/driver:580.95.05-rocky8.10"
  Warning  Failed          3m36s (x4 over 4m56s)   kubelet            Failed to pull image "nvcr.io/nvidia/driver:580.95.05-rocky8.10": rpc error: code = NotFound desc = failed to pull and unpack image "nvcr.io/nvidia/driver:580.95.05-rocky8.10": failed to resolve reference "nvcr.io/nvidia/driver:580.95.05-rocky8.10": nvcr.io/nvidia/driver:580.95.05-rocky8.10: not found
  Warning  Failed          3m36s (x4 over 4m56s)   kubelet            Error: ErrImagePull
  Warning  Failed          3m25s (x4 over 4m32s)   kubelet            Error: ImagePullBackOff
  Normal   BackOff         24s (x17 over 4m32s)    kubelet            Back-off pulling image "nvcr.io/nvidia/driver:580.95.05-rocky8.10"
Here’s the helm command that I used
helm install --wait --generate-name     -n gpu-operator --create-namespace     nvidia/gpu-operator     --version=v25.10.0     --set driver.enabled=true     --set toolkit.enabled=true     --set devicePlugin.enabled=truekubectl -n rag create secret generic ngc-credentials   --from-literal=NGC_API_KEY='<license key redacted>'
helm install --wait --generate-name     -n gpu-operator --create-namespace     nvidia/gpu-operator     --version=latest     --set driver.enabled=true     --set toolkit.enabled=true     --set devicePlugin.enabled=truekubectl -n rag create secret generic ngc-credentials   --from-literal=NGC_API_KEY='<license key redacted>'
