GPU power is maxout then inference is running with tensorrt
My GPU RTX A6000 is used full available power due to report from nvtop (300W of 300W). If I understand correctly it must use less power because we use tensor cores instead of cuda cores. Whats going on and how to fix power consumption?
I converted my onnx model with next command:
trtexec --onnx=/weights/onnx/model_srgan.onnx --saveEngine=/weights/onnx/model-rt.trt --best --workspace=40000
And then I run inference:
trtexec --loadEngine=/weights/onnx/model-rt.trt --iterations=1000
And here is nvtop screenshot that shows full usage of GPU watts and cuda cores.
My model here (this is srgan model from tensorflow hub converted to onnx):
model_srgan.onnx (17.8 MB)
I used next docker container for all of my tests:
nvcr.io/nvidia/tensorrt:22.11-py3
Request you to share the ONNX model and the script if not shared already so that we can assist you better.
Alongside you can try few things:
  1. validating your model with the below snippet
check_model.py
import sys
import onnx
filename = yourONNXmodel
model = onnx.load(filename)
onnx.checker.check_model(model).
2) Try running your model with trtexec command.
In case you are still facing issue, request you to share the trtexec “”–verbose"" log for further debugging
All files is already attached to the first post.
Do any one have answer?
Apologies for the delayed repsonse.
Could you please share with us the trtexec .... --verbose logs for better debugging.
Thank you.
