Hallo,
i tried to start the “Multi-threading Example” from https://devblogs.nvidia.com/parallelforall/gpu-pro-tip-cuda-7-streams-simplify-concurrency/ using a win7 system with visual studio 2012 and a nvidia titan X GPU. so i started to get “pthread” ready by following the instructions from http://web.cs.du.edu/~sturtevant/w13-sys/InstallingpthreadsforVisualStudio.pdf.
but setting the nvcc flag “–default-stream per-thread” as mentioned in https://devblogs.nvidia.com/parallelforall/gpu-pro-tip-cuda-7-streams-simplify-concurrency/ does not alter the profile obtained by NSIGHT. moreover no errors or warnings are raised.
so i added the lines
cudaError_t cudaStatus;
if (cudaStatus != cudaSuccess) {
printf(“ERROR, KERNEL FAILED: %s\n”, cudaGetErrorString(cudaStatus));
before the actual kernel launch and get the following error: “unrecognized error code”.
in case of launching the kernel without the use of “pthread”, no error is obtained.
does anyone know what is going on here?
