GPU running time is not stable
:unsure: I just running the test code on HP Z800 WORKSTATION with CENTOS 5.4 64BIT(FX1800+TESLA C1060)
the GPU calculation speed changes everytime
$ ./a.out
Max error: 1.19209e-07 Average error: 4.22521e-08
Time used: 0.1100 (18.18 GFLOPS)
$ ./a.out
Time used: 0.0900 (22.22 GFLOPS)
$ ./a.out
$ ./a.out
Time used: 0.0700 (28.57 GFLOPS)
$ ./a.out
for validation, I have removed tesla c1060, and move fx1800 to PCIE-8X slot, the resule 12.5-15.38GFLOPS)
are there sth wrong on the software and system driver,
further more, are there some sample code to compare cpu and GPU calculation speed?
regards
feng
the test code as follows:
æµ‹è¯•ç¨‹åºä»£ç å¦‚ä¸‹ï¼š
// Second CUDA program
// Ping-Che Chen
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <cuda_runtime.h>
#define BLOCK_SIZE 16
global static void matMultCUDA(const float* a, size_t lda, const float* b, size_t ldb, float* c, size_t ldc, int n)
shared float matA[BLOCK_SIZE][BLOCK_SIZE];
shared float matB[BLOCK_SIZE][BLOCK_SIZE];
const int tidc = threadIdx.x;
const int tidr = threadIdx.y;
const int bidc = blockIdx.x * BLOCK_SIZE;
const int bidr = blockIdx.y * BLOCK_SIZE;
int i, j;
float results = 0;
float comp = 0;
for(j = 0; j < n; j += BLOCK_SIZE) {
matA[tidr][tidc] = a[(tidr + bidr) * lda + tidc + j];
matB[tidr][tidc] = b[(tidr + j) * ldb + tidc + bidc];
__syncthreads();
for(i = 0; i < BLOCK_SIZE; i++) {
float t;
comp -= matA[tidr][i] * matB[i][tidc];
t = results - comp;
comp = (t - results) + comp;
results = t;
__syncthreads();
c[(tidr + bidr) * ldc + tidc + bidc] = results;
clock_t matmultCUDA(const float* a, int lda, const float* b, int ldb, float* c, int ldc, int n)
float *ac, *bc, *cc;
clock_t start, end;
size_t pitch_a, pitch_b, pitch_c;
int newn = ((n + BLOCK_SIZE - 1) / BLOCK_SIZE) * BLOCK_SIZE;
start = clock();
cudaMallocPitch((void**) &ac, &pitch_a, sizeof(float) * newn, newn);
cudaMallocPitch((void**) &bc, &pitch_b, sizeof(float) * newn, newn);
cudaMallocPitch((void**) &cc, &pitch_c, sizeof(float) * newn, newn);
cudaMemset(ac, 0, pitch_a * newn);
cudaMemset(bc, 0, pitch_b * newn);
cudaMemcpy2D(ac, pitch_a, a, sizeof(float) * lda, sizeof(float) * n, n, cudaMemcpyHostToDevice);
cudaMemcpy2D(bc, pitch_b, b, sizeof(float) * ldb, sizeof(float) * n, n, cudaMemcpyHostToDevice);
int bx = (n + BLOCK_SIZE - 1) / BLOCK_SIZE;
dim3 blocks(bx, bx);
dim3 threads(BLOCK_SIZE, BLOCK_SIZE);
matMultCUDA<<<blocks, threads>>>(ac, pitch_a / sizeof(float), bc, pitch_b / sizeof(float), cc, pitch_c / sizeof(float), n);
cudaMemcpy2D(c, sizeof(float) * ldc, cc, pitch_c, sizeof(float) * n, n, cudaMemcpyDeviceToHost);
cudaFree(ac);
cudaFree(bc);
cudaFree(cc);
end = clock();
return end - start;
void matmult(const float* a, int lda, const float* b, int ldb, float* c, int ldc, int n)
int i, j, k;
for(i = 0; i < n; i++) {
for(j = 0; j < n; j++) {
double t = 0;
for(k = 0; k < n; k++) {
t += a[i * lda + k] * b[k * ldb + j];
c[i * ldc + j] = t;
void matgen(float* a, int lda, int n)
int i, j;
a[i * lda + j] = (float) rand() / RAND_MAX + (float) rand() / (RAND_MAX * RAND_MAX);
void compare_mat(const float* a, int lda, const float* b, int ldb, int n)
float max_err = 0;
float average_err = 0;
int i, j;
if(b[i * ldb + j] != 0) {
float err = fabs((a[i * lda + j] - b[i * ldb + j]) / b[i * ldb + j]);
if(max_err < err) max_err = err;
average_err += err;
printf(“Max error: %g Average error: %g\n”, max_err, average_err / (n * n));
bool InitCUDA()
int count;
cudaGetDeviceCount(&count);
if(count == 0) {
fprintf(stderr, “There is no device.\n”);
return false;
int i;
for(i = 0; i < count; i++) {
cudaDeviceProp prop;
if(cudaGetDeviceProperties(&prop, i) == cudaSuccess) {
if(prop.major >= 1) {
break;
if(i == count) {
fprintf(stderr, “There is no device supporting CUDA 1.x.\n”);
return false;
cudaSetDevice(i);
return true;
int main()
float *a, *b, *c, *d;
int n = 1000;
if(!InitCUDA()) {
return 0;
a = (float*) malloc(sizeof(float) * n * n);
b = (float*) malloc(sizeof(float) * n * n);
c = (float*) malloc(sizeof(float) * n * n);
d = (float*) malloc(sizeof(float) * n * n);
srand(0);
matgen(a, n, n);
matgen(b, n, n);
clock_t time = matmultCUDA(a, n, b, n, c, n, n);
matmult(a, n, b, n, d, n, n);
compare_mat(c, n, d, n, n);
double sec = (double) time / CLOCKS_PER_SEC;
printf(“Time used: %.4lf (%.2lf GFLOPS)\n”, sec, 2.0 * n * n * n / (sec * 1E9));
free(a);
free(B);
free©;
free(d);
return 0;
Is it speed in seconds? 0.1 second? need to run about a few mins to get stable results. I can say such different speed is normal. Also this implementation of matmul is far from optimal. There is more optimal implementation in cuda library.
You’re also timing cudaMalloc and cudaFree, and you’re not cooking the kernel (call the kernel at least once before taking measurements - the first call of each kernel takes a little longer).
Even worse, the first call to cudaMallocPitch will set up the CUDA context. Expect some 40ms of extra delay right there. You could force context creation earlier by calling cudaFree(NULL) right after your cudaSetDevice() call (this is assuming cudaSetDevice is not creating the CUDA context for this device, I am not 100% sure about that).
cudaSetDevice does not create a context. It only sets the GPU # for the future context creation.
did " cudaFree(NULL)" means the cuda program warm up in many cuda presentation?
