GPU slower than CPU in COO SpMV Multiplication?
Hi.
I am experimenting with SpMV multiplication. Matrix is in COO format. I use kernels from the cusp-library (Google Code Archive - Long-term storage for Google Code Project Hosting.). Here’s the full source code of my programe:
[codebox]#include <stdio.h>
#include <stdlib.h>
#include <cuda.h>
#include
#include <sys/time.h>
#include <cutil.h>
#include <cutil_inline.h>
#include “mmio.c”
#define DIVIDE_INTO(x, y) ((x + y - 1)/y)
const unsigned int WARP_SIZE = 32;
const unsigned int MAX_THREADS = 512;
const unsigned int BLOCK_SIZE = 256;
const unsigned int MAX_BLOCKS = MAX_THREADS / (2 * BLOCK_SIZE);
const unsigned int WARPS_PER_BLOCK = BLOCK_SIZE / WARP_SIZE;
const bool UseCache = false;
typedef int IndexType;
typedef double ValueType;
texture<int2,1> tex_x_double;
void bind_x(const double * x)
{ CUDA_SAFE_CALL(cudaBindTexture(NULL, tex_x_double, x)); }
void unbind_x(const double * x)
{ CUDA_SAFE_CALL(cudaUnbindTexture(tex_x_double)); }
inline device double fetch_x(const int& i, const double * x)
#if CUDA_ARCH >= 130
// double requires Compute Capability 1.3 or greater
if (UseCache)
  int2 v = tex1Dfetch(tex_x_double, i);
  return __hiloint2double(v.y, v.x);
else
  return x[i];
#else
return 1.0/0.0; // should never be called
#endif
texture<float,1> tex_x_float;
void bind_x(const float * x)
{ CUDA_SAFE_CALL(cudaBindTexture(NULL, tex_x_float, x)); }
void unbind_x(const float * x)
{ CUDA_SAFE_CALL(cudaUnbindTexture(tex_x_float)); }
inline device float fetch_x(const int& i, const float * x)
if (UseCache)
    return tex1Dfetch(tex_x_float, i);
else
    return x[i];
void checkCUDAError(const char *msg)
cudaError_t err = cudaGetLastError();
if( cudaSuccess != err)
  fprintf(stderr, "Cuda error: %s: %s.\n", msg,
    cudaGetErrorString( err) );
  exit(EXIT_FAILURE);
// segmented reduction in shared memory
device ValueType segreduce_warp(const IndexType thread_lane, IndexType row, ValueType val, IndexType * rows, ValueType * vals)
rows[threadIdx.x] = row;
vals[threadIdx.x] = val;
if( thread_lane >= 1 && row == rows[threadIdx.x - 1] ) { vals[threadIdx.x] = val = val + vals[threadIdx.x - 1]; }
if( thread_lane >=  2 && row == rows[threadIdx.x -  2] ) { vals[threadIdx.x] = val = val + vals[threadIdx.x -  2]; }
if( thread_lane >=  4 && row == rows[threadIdx.x -  4] ) { vals[threadIdx.x] = val = val + vals[threadIdx.x -  4]; }
if( thread_lane >=  8 && row == rows[threadIdx.x -  8] ) { vals[threadIdx.x] = val = val + vals[threadIdx.x -  8]; }
if( thread_lane >= 16 && row == rows[threadIdx.x - 16] ) { vals[threadIdx.x] = val = val + vals[threadIdx.x - 16]; }
return val;
global void
spmv_coo_kernel(const IndexType num_nonzeros,
                 const IndexType interval_size,
                 const IndexType * I,
                 const IndexType * J,
                 const ValueType * V,
                 const ValueType * x,
                       ValueType * y,
                       IndexType * temp_rows,
                       ValueType * temp_vals)
__shared__ volatile IndexType rows[48 *(BLOCK_SIZE/32)];
__shared__ volatile ValueType vals[BLOCK_SIZE];
const IndexType thread_id = BLOCK_SIZE * blockIdx.x + threadIdx.x; // global thread index
const IndexType thread_lane = threadIdx.x & (WARP_SIZE-1);                           // thread index within the warp
const IndexType warp_id     = thread_id   / WARP_SIZE;                               // global warp index
const IndexType interval_begin = warp_id * interval_size; // warp’s offset into I,J,V
const IndexType interval_end   = min(interval_begin + interval_size, num_nonzeros);  // end of warps's work
const IndexType idx = 16 * (threadIdx.x/32 + 1) + threadIdx.x; // thread’s index into padded rows array
rows[idx - 16] = -1; // fill padding with invalid row index
if(interval_begin >= interval_end) // warp has no work to do
    return;
if (thread_lane == 31)
    // initialize the carry in values
    rows[idx] = I[interval_begin];
    vals[threadIdx.x] = 0;
for(IndexType n = interval_begin + thread_lane; n < interval_end; n += WARP_SIZE)
    IndexType row = I[n];                                         // row index (i)
    ValueType val = V[n] * fetch_x(J[n], x);            // A(i,j) * x(j)
if (thread_lane == 0)
        if(row == rows[idx + 31])
            val += vals[threadIdx.x + 31];                        // row continues
        else
            y[rows[idx + 31]] += vals[threadIdx.x + 31];  // row terminated
rows[idx] = row;
if(row == rows[idx - 1]) { vals[threadIdx.x] = val = val + vals[threadIdx.x - 1]; }
    if(row == rows[idx -  2]) { vals[threadIdx.x] = val = val + vals[threadIdx.x -  2]; }
    if(row == rows[idx -  4]) { vals[threadIdx.x] = val = val + vals[threadIdx.x -  4]; }
    if(row == rows[idx -  8]) { vals[threadIdx.x] = val = val + vals[threadIdx.x -  8]; }
    if(row == rows[idx - 16]) { vals[threadIdx.x] = val = val + vals[threadIdx.x - 16]; }
if(thread_lane < 31 && row != rows[idx + 1])
        y[row] += vals[threadIdx.x];                                            // row terminated
if(thread_lane == 31)
    // write the carry out values
    temp_rows[warp_id] = rows[idx];
    temp_vals[warp_id] = vals[threadIdx.x];
// Segmented redction
device void segreduce_block(const IndexType * idx, ValueType * val)
ValueType left = 0;
if( threadIdx.x >=   1 && idx[threadIdx.x] == idx[threadIdx.x -   1] ) { left = val[threadIdx.x -   1]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >=   2 && idx[threadIdx.x] == idx[threadIdx.x -   2] ) { left = val[threadIdx.x -   2]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >=   4 && idx[threadIdx.x] == idx[threadIdx.x -   4] ) { left = val[threadIdx.x -   4]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >=   8 && idx[threadIdx.x] == idx[threadIdx.x -   8] ) { left = val[threadIdx.x -   8]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >=  16 && idx[threadIdx.x] == idx[threadIdx.x -  16] ) { left = val[threadIdx.x -  16]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >=  32 && idx[threadIdx.x] == idx[threadIdx.x -  32] ) { left = val[threadIdx.x -  32]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >=  64 && idx[threadIdx.x] == idx[threadIdx.x -  64] ) { left = val[threadIdx.x -  64]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >= 128 && idx[threadIdx.x] == idx[threadIdx.x - 128] ) { left = val[threadIdx.x - 128]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
if( threadIdx.x >= 256 && idx[threadIdx.x] == idx[threadIdx.x - 256] ) { left = val[threadIdx.x - 256]; } __syncthreads(); val[threadIdx.x] += left; left = 0; __syncthreads();
// The second level of the segmented reduction operation
global void
spmv_coo_reduce_update_kernel(const IndexType num_warps,
                          const IndexType * temp_rows,
                          const ValueType * temp_vals,
                                ValueType * y)
__shared__ IndexType rows[BLOCK_SIZE + 1];
__shared__ ValueType vals[BLOCK_SIZE + 1];
const IndexType end = num_warps - (num_warps & (BLOCK_SIZE - 1));
if (threadIdx.x == 0)
    rows[BLOCK_SIZE] = (IndexType) -1;
    vals[BLOCK_SIZE] = (ValueType)  0;
__syncthreads();
IndexType i = threadIdx.x;
while (i < end)
    // do full blocks
    rows[threadIdx.x] = temp_rows[i];
    vals[threadIdx.x] = temp_vals[i];
__syncthreads();
segreduce_block(rows, vals);
if (rows[threadIdx.x] != rows[threadIdx.x + 1])
        y[rows[threadIdx.x]] += vals[threadIdx.x];
__syncthreads();
i += BLOCK_SIZE;
if (end < num_warps){
    if (i < num_warps){
    } else {
        rows[threadIdx.x] = (IndexType) -1;
        vals[threadIdx.x] = (ValueType)  0;
__syncthreads();
if (i < num_warps)
global void
spmv_coo_serial_kernel(const IndexType num_nonzeros,
                         ValueType * y)
for(IndexType n = 0; n < num_nonzeros; n++){
    y[I[n]] += V[n] * x[J[n]];
// prosty algorytm mnozacy na CPU
void
spmv_coo_CPU(const IndexType num_nonzeros,
       	   ValueType * y)
IndexType i;
for (i = 0; i < num_nonzeros; i++)
  y[I[i]] += V[i] * x[J[i]];
int main(int argc, char *argv)
int ret_code;
MM_typecode matcode;
FILE *f;
int M, N, nz;
int i, s;
struct timeval tStart, tStop, tInterval;
unsigned int hTimer;
double czas;
IndexType *h_I, *h_J;
ValueType *h_V, *h_x, *h_y, *h_y_cpu;
if (argc < 2)
  fprintf(stderr, "Uzycie: %s [nazwa-pliku]\n", argv[0]);
  exit(1);
else
  if ((f = fopen(argv[1], "r")) == NULL)
 exit(1);
if (mm_read_banner(f, &matcode) != 0)
  printf("Could not process Matrix Market banner.\n");
  exit(1);
/* This is how one can screen matrix types if their application */
/* only supports a subset of the Matrix Market data types. */
if (mm_is_complex(matcode) && mm_is_matrix(matcode) &&
 mm_is_sparse(matcode) )
  printf("Sorry, this application does not support ");
  printf("Market Market type: [%s]\n", mm_typecode_to_str(matcode));
  exit(1);
printf(“Loading data…\n”);
if ((ret_code = mm_read_mtx_crd_size(f, &N, &M, &nz)) != 0)
  exit(1);
size_t size_index = nz * sizeof(IndexType);
size_t size_value = nz * sizeof(ValueType);
h_I = (IndexType *) malloc(size_index);
h_J = (IndexType *) malloc(size_index);
h_V = (ValueType *) malloc(size_value);
for (i = 0; i < nz; ++i)
  fscanf(f, "%d %d %lf\n", &h_J[i], &h_I[i], &h_V[i]);
  h_I[i]--;
  h_J[i]--;
if (f != stdin) fclose(f);
size_t size_vec = M * sizeof(ValueType);
h_x = (ValueType *) malloc(size_vec);
for (i = 0; i < M; i++)
  h_x[i] = 2.0+i*0.005;
h_y = (ValueType *) calloc(M, sizeof(ValueType));
h_y_cpu = (ValueType *) calloc(M, sizeof(ValueType));
IndexType *d_I, *d_J;
ValueType *d_V, *d_x, *d_y;
cudaMalloc((void**)&d_I, size_index);
cudaMalloc((void**)&d_J, size_index);
cudaMalloc((void**)&d_V, size_value);
cudaMalloc((void**)&d_x, size_vec);
cudaMalloc((void**)&d_y, size_vec);
checkCUDAError(“cudaMalloc”);
cudaMemcpy(d_I, h_I, size_index, cudaMemcpyHostToDevice);
cudaMemcpy(d_J, h_J, size_index, cudaMemcpyHostToDevice);
cudaMemcpy(d_V, h_V, size_value, cudaMemcpyHostToDevice);
cudaMemcpy(d_x, h_x, size_vec, cudaMemcpyHostToDevice);
cudaMemcpy(d_y, h_y, size_vec, cudaMemcpyHostToDevice);
checkCUDAError(“cudaMemcpy to device”);
s = M/10;
if (s == 0)
  s = 1;
printf(“s = %d\n”, s);
printf(“CPU multiplication…\n”);
cutCreateTimer(&hTimer);
  cutResetTimer(hTimer);
  cudaThreadSynchronize();
  cutStartTimer(hTimer);
spmv_coo_CPU(nz, h_I, h_J, h_V, h_x, h_y_cpu);
cutStopTimer(hTimer);
printf(“Execution time (CPU) = %lf ms\n”, cutGetTimerValue(hTimer));
cutDeleteTimer(hTimer);
printf(“Result:\n”);
for (int k = 0; k < M; k+=s)
  printf("y[%d] = %lf\n", k, h_y_cpu[k]);
if (nz == 0)
  printf("Empty matrix\n");
else if (nz < WARP_SIZE)
  printf("Small matrix\n");
  spmv_coo_serial_kernel <<<1,1>>>
        (nz, d_I, d_J, d_V, d_x, d_y);
  cudaMemcpy(h_y, d_y, size_vec, cudaMemcpyDeviceToHost);
  printf("Result:\n");
  for (i = 0; i < M; ++i)
 printf("%lf ", h_y[i]);
  printf("\n");
else
  const unsigned int num_units = nz / WARP_SIZE;
  const unsigned int num_warps = std::min(num_units, WARPS_PER_BLOCK * MAX_BLOCKS);
  const unsigned int num_blocks = DIVIDE_INTO(num_warps, WARPS_PER_BLOCK);
  const unsigned int num_iters = DIVIDE_INTO(num_units, num_warps);
const unsigned int interval_size = WARP_SIZE * num_iters;
const IndexType tail = num_units * WARP_SIZE;
const unsigned int active_warps = (interval_size == 0) ? 0 : DIVIDE_INTO(tail, interval_size);
printf(“num_units = %u\n”, num_units);
  printf("num_warps = %u\n", num_warps);
  printf("num_blocks = %u\n", num_blocks);
  printf("num_inters = %u\n", num_iters);
  printf("interval_size = %u\n", interval_size);
  printf("tail = %d\n", tail);
  printf("active_warps = %u\n", active_warps);
if (UseCache)
 bind_x(d_x);
  checkCUDAError("bind");
IndexType * temp_rows;
  ValueType * temp_vals;
cudaMalloc((void**)&temp_rows, active_warps * sizeof(IndexType));
  cudaMalloc((void**)&temp_vals, active_warps * sizeof(ValueType));
// Odpalamy kernel
  printf("GPU multiplication...\n");
 cutilCheckError(cutCreateTimer(&hTimer));
 cutilCheckError(cutResetTimer(hTimer));
 cutilCheckError(cutStartTimer(hTimer));
 spmv_coo_kernel <<<num_blocks,BLOCK_SIZE>>>
    (tail, interval_size, d_I, d_J, d_V, d_x, d_y, temp_rows, temp_vals);
    (nz - tail, d_I + tail, d_J + tail, d_V + tail, d_x, d_y);
 spmv_coo_reduce_update_kernel <<<1, 512>>>
    (active_warps, temp_rows, temp_vals, d_y);
 cutilCheckError(cutStopTimer(hTimer));
 checkCUDAError("wywoanie kerneli");
 printf("Execution time (GPU) = %lf ms\n", cutGetTimerValue(hTimer));
cudaFree(temp_rows);
  cudaFree(temp_vals);
if (UseCache)
 unbind_x(d_x);
  checkCUDAError("cudaMemcpy to host");
 printf("y[%d] = %lf\n", k, h_y[k]);
free(h_I);
free(h_J);
free(h_V);
free(h_x);
free(h_y);
free(h_y_cpu);
cudaFree(d_I);
cudaFree(d_J);
cudaFree(d_V);
cudaFree(d_x);
cudaFree(d_y);
return 0;
[/codebox]
Results of this programme are strange. CPU seems to be faster than GPU. Example results:
$ release/spmv ../mtx/hood.mtx
Loading data...
s = 22054
CPU multiplication...
Execution time (CPU) = 40.953999 ms
Result:
y[0] = 1063117684.283157
y[22054] = 12640207895.224644
y[44108] = -33255447.632059
y[66162] = 868046245.778653
y[88216] = 261818029.206334
y[110270] = 222523762.127168
y[132324] = 1407517451.698023
y[154378] = 327192007.079969
y[176432] = 4373661739.092607
y[198486] = -66860974.932954
y[220540] = 2416760813.382476
num_units = 171702
num_warps = 8
num_blocks = 1
num_inters = 21463
interval_size = 686816
tail = 5494464
active_warps = 8
Execution time (GPU) = 86.750999 ms
Result:
y[44108] = -33255447.632060
y[132324] = 1407517451.698022
GPU is over 2 times slower. Why? What am I doing wrong? My graphic card is GeForce GTX 275.
