Hello to everyone!
I have HP ProBook 440 G7 with GeForce MX250 and Intel UHD. It works perfect in MS Windows, but i need something different.
I’ve tried Ubuntu 16,18,20 and 21 with 450, 460, 465, 470 drivers (can’t use nouveau because i need CUDA) and always have the same problem:
If i had run something that uses GPU (glxgears for example) - system works fine, but when PC stays idle for a few minutes - display image freezes without any motion.
System remains working, because I can still have access via ssh.
In /var/log/syslog:
Aug 19 13:33:21 MS205-Ubuntu kernel: [16901.313570] NVRM: GPU at PCI:0000:01:00: GPU-cfd334e0-13dd-25cc-089d-e1bc2a82f678
Aug 19 13:33:21 MS205-Ubuntu kernel: [16901.313579] NVRM: Xid (PCI:0000:01:00): 79, pid=0, GPU has fallen off the bus.
Aug 19 13:33:21 MS205-Ubuntu kernel: [16901.313584] NVRM: GPU 0000:01:00.0: GPU has fallen off the bus.
Aug 19 13:33:21 MS205-Ubuntu kernel: [16901.313621] NVRM: A GPU crash dump has been created. If possible, please run
Aug 19 13:33:21 MS205-Ubuntu kernel: [16901.313621] NVRM: nvidia-bug-report.sh as root to collect this data before
Aug 19 13:33:21 MS205-Ubuntu kernel: [16901.313621] NVRM: the NVIDIA kernel module is unloaded.
nvidia-bug-report.log (2.7 MB)
I’ve tried to turn off Extended Idle Power States and Runtime Power Management in BIOS but it doesn’t help. Booting with intel_idle.max_cstate=1 doesn’t help also.
