This may be similar to
My camera pipeline normally does not lose frames and consumes 55-60% of GPU time on average, as reported by tegrastats.
But when temperature reaches 70C - hot-surface alert appears and suddenly GPU usage jumps to 95+% and frame loss occurs.
I distilled this down to interaction between Gtk popup notification utilized by /usr/share/nvpmodel_indicator/nvpmodel_indicator.py and NvEglRenderer in full screen mode.
To reproduce first make this small python code, which calls the same API as nvpmodel_indicator.py:
cat <<EOF > warning.py
import os
import gi
gi.require_version("Gtk", "3.0")
gi.require_version('AppIndicator3', '0.1')
gi.require_version('Notify', '0.7')
from gi.repository import Gtk as gtk
from gi.repository import AppIndicator3 as appindicator
from gi.repository import Notify as notify
from gi.repository import GLib
INDICATOR_ID = 'test'
ICON_DEFAULT = os.path.abspath('/usr/share/nvpmodel_indicator/nv_logo.svg')
ICON_WARNING = 'dialog-warning'
notify.init(INDICATOR_ID)
warning = notify.Notification()
warning.update("Sample warning message")
warning.show()
EOF
Verify that Orin AGX DevKit is in MAXN mode, then run jetsonclock and tegrastats (with some filter for clarity):
sudo nvpmodel -q # Should print NV Power Mode: MAXN
sudo /usr/bin/jetson_clocks
tegrastats | sed -n 's@\(..-..-.... ..:..:..\).*\(GR3D_FREQ\) \(....\).*\(tj\)\(.....\).*@\1,\2,\3,\4,\5@p'
note that currently “GR3D_FREQ,0%”
In another shell run some GPU code with NvEglRenderer:
DISPLAY=:0 ./video_dec_cuda /usr/src/jetson_multimedia_api/data/Video/sample_outdoor_car_1080p_10fps.h264 H264 --fullscreen -fps 60
Observe GR3D_FREQ numbers in the middle of video (your numbers may vary depending on display resolution):
11-01-2024 20:44:42,GR3D_FREQ,10% ,tj,@48.0
11-01-2024 20:44:43,GR3D_FREQ,12% ,tj,@48.0
11-01-2024 20:44:44,GR3D_FREQ,7% c,tj,@48.1
11-01-2024 20:44:45,GR3D_FREQ,7% c,tj,@48.1
11-01-2024 20:44:46,GR3D_FREQ,7% c,tj,@48.0
11-01-2024 20:44:47,GR3D_FREQ,6% c,tj,@48.3
Now run
DISPLAY=:0 python3 warning.py
And again:
Now GR3D_FREQ increased almost 4 times! It does not loose frames because this video is so tiny, but if you will replace it by larger one, it will lose frames!
11-01-2024 20:46:02,GR3D_FREQ,38% ,tj,@47.7
11-01-2024 20:46:03,GR3D_FREQ,38% ,tj,@47.9
11-01-2024 20:46:04,GR3D_FREQ,40% ,tj,@47.7
11-01-2024 20:46:05,GR3D_FREQ,39% ,tj,@47.8
11-01-2024 20:46:06,GR3D_FREQ,37% ,tj,@47.8
I am not sure, but I suspect the same problem happens with other Ubuntu notifications such as the dreaded Software Updates reminder.
In ncu profier output I see that some CUDA operations take many times longer than in normal case without any obvious blocker.
May be X window manager or compositor took so much GPU? How to control that?
Should we disable all popup notifications and what is the best way to do that?
Thank you
