Environment
TensorRT Version: 8.4.1-1+cuda11.6
GPU Type: RTX 3090
Nvidia Driver Version: 515.57
CUDA Version: 11.7
Operating System + Version: Ubuntu 20.04.5 LTS
Python Version (if applicable): 3.8
TensorFlow Version (if applicable): N/A
Steps To Reproduce
- Install TensorRT
- Install Deepstream 6.1
- Install Graph Composer 2.0
- Download and install the reference graph package
- Install Prerequisites by this instruction
- Run sample graph reference “deepstream-test1” on my local machine
- Build container image on Jetson
I can run sample graph reference “deepstream-test1” on my local machine, but I failed building container image on Jetson. How can I make it works, please help. : (
2022-07-13 16:18:42,917 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - work folder: /home/rt/.cache/container_builder/.workfolder_10037 is ready
2022-07-13 16:18:42,917 - ContainerBuilder.container_builder.docker_manager.docker_manager - INFO - start build docker file /home/rt/.cache/container_builder/.dockerfile_10037
2022-07-13 08:18:44 [384,822ms] [Error] [omni.kit.app.impl] [py stderr]: Exception in thread Thread-1:
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/urllib3/connectionpool.py", line 710, in urlopen
chunked=chunked,
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/urllib3/connectionpool.py", line 398, in _make_request
conn.request(method, url, **httplib_request_kw)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/http/client.py", line 1281, in request
self._send_request(method, url, body, headers, encode_chunked)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/http/client.py", line 1327, in _send_request
self.endheaders(body, encode_chunked=encode_chunked)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/http/client.py", line 1276, in endheaders
self._send_output(message_body, encode_chunked=encode_chunked)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/http/client.py", line 1075, in _send_output
self.send(chunk)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/http/client.py", line 997, in send
self.sock.sendall(data)
ConnectionResetError: [Errno 104] Connection reset by peer
During handling of the above exception, another exception occurred:
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/requests/adapters.py", line 450, in send
timeout=timeout
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/urllib3/connectionpool.py", line 786, in urlopen
method, url, error=e, _pool=self, _stacktrace=sys.exc_info()[2]
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/urllib3/util/retry.py", line 550, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/urllib3/packages/six.py", line 769, in reraise
raise value.with_traceback(tb)
chunked=chunked,
self.send(chunk)
urllib3.exceptions.ProtocolError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/threading.py", line 926, in _bootstrap_inner
self.run()
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/threading.py", line 870, in run
self._target(*self._args, **self._kwargs)
File "./container_builder/cli/container_builder_runtime.py", line 44, in build
ret = docker_manager.build_main_yaml(graph_target=graph_target)
File "./container_builder/docker_manager/docker_manager.py", line 457, in build_main_yaml
if not self.build_stage_image(image_name):
File "./container_builder/docker_manager/docker_manager.py", line 528, in build_stage_image
nocache, squash)
File "./container_builder/docker_manager/docker_builder.py", line 119, in build_from
self._internal_build(**builds)
File "./container_builder/docker_manager/docker_builder.py", line 69, in _internal_build
stream = self._client.api.build(decode=True, **kwargs)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/docker/api/build.py", line 269, in build
timeout=timeout,
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/docker/utils/decorators.py", line 46, in inner
return f(self, *args, **kwargs)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/docker/api/client.py", line 233, in _post
return self.post(url, **self._set_request_timeout(kwargs))
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/requests/sessions.py", line 577, in post
return self.request('POST', url, data=data, json=json, **kwargs)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/requests/sessions.py", line 529, in request
resp = self.send(prep, **send_kwargs)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/requests/sessions.py", line 645, in send
r = adapter.send(request, **kwargs)
File "/tmp/.tmpNvXgRaphComposer/run/kit/python/lib/python3.7/requests/adapters.py", line 501, in send
raise ConnectionError(err, request=request)
requests.exceptions.ConnectionError: ('Connection aborted.', ConnectionResetError(104, 'Connection reset by peer'))
chunked=chunked,
self.send(chunk)
timeout=timeout
chunked=chunked,
self.send(chunk)
self.run()
nocache, squash)
timeout=timeout,
