Graph Composer Multi Source Input Container Error
Hardware Platform (Jetson / GPU) RTX3050
DeepStream Version 6.2
TensorRT Version 8.5.3
NVIDIA GPU Driver Version (valid for GPU only) 525.85.12
Issue Type( questions, new requirements, bugs) bug
I’m using a Multi Source Input in my Graph. When running the graph locally from composer - all works as expected. However when I containerise the graph and launch the container locally - I get the following error. ( Missing parser: MPEG-4 AAC )
PS: With a single Source input the container runs fine.
See below console log…
2023-03-26 15:54:19.495 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin0/GstParseBin:aparsebin: Your GStreamer installation is missing a plug-in.
2023-03-26 15:54:19.495 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:
gstparsebin.c(3486): gst_parse_bin_expose (): /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin0/GstParseBin:aparsebin:
no suitable plugins found:
Missing parser: MPEG-4 AAC (audio/mpeg, mpegversion=(int)4, stream-format=(string)raw, codec_data=(buffer)1588)
2023-03-26 15:54:19.495 ERROR extensions/nvdsbase/nvds_scheduler.cpp@349: Error from /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin0/GstParseBin:aparsebin: Your GStreamer installation is missing a plug-in.
2023-03-26 15:54:19.495 ERROR extensions/nvdsbase/nvds_scheduler.cpp@351: Debug info:
Returned, stopping playback
2023-03-26 15:54:19.505 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin1/GstParseBin:aparsebin: Your GStreamer installation is missing a plug-in.
2023-03-26 15:54:19.505 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:
gstparsebin.c(3486): gst_parse_bin_expose (): /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin1/GstParseBin:aparsebin:
How can I resolve this?
Can the graph work after the error log output?
No - It does not - It seems the pipeline actually starts - but then crashes… Below is the full output…
2023-03-27 06:56:28.847 INFO  gxf/gxe/gxe.cpp@180: Creating context
2023-03-27 06:56:29.022 INFO  gxf/gxe/gxe.cpp@105: Loading app: 'One.yaml'
2023-03-27 06:56:29.022 INFO  gxf/std/yaml_file_loader.cpp@129: Loading GXF entities from YAML file 'One.yaml'...
2023-03-27 06:56:29.024 INFO  gxf/gxe/gxe.cpp@105: Loading app: 'parameters.yaml'
2023-03-27 06:56:29.024 INFO  gxf/std/yaml_file_loader.cpp@129: Loading GXF entities from YAML file 'parameters.yaml'...
2023-03-27 06:56:29.024 INFO  gxf/gxe/gxe.cpp@249: Initializing...
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.042: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstopenmpt.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.053: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2enc.so': libmpeg2encpp-2.1.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.072: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpg123.so': libmpg123.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.106: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstmpeg2dec.so': libmpeg2.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.140: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/libgstchromaprint.so': libavcodec.so.58: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.319: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_inferserver.so': libtritonserver.so: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.337: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_ucx.so': libucs.so.0: cannot open shared object file: No such file or directory
(gst-plugin-scanner:7): GStreamer-WARNING **: 06:56:29.340: Failed to load plugin '/usr/lib/x86_64-linux-gnu/gstreamer-1.0/deepstream/libnvdsgst_udp.so': librivermax.so.0: cannot open shared object file: No such file or directory
2023-03-27 06:56:29.491 INFO  extensions/nvdsbase/nvds_scheduler.cpp@270: This program is linked against GStreamer 1.16.3
2023-03-27 06:56:29.492 INFO  extensions/nvdsinference/nvinferbin.hpp@24: initialize: nvinferbin object_detector
2023-03-27 06:56:29.492 INFO  extensions/nvdsvisualization/nvosdbin.hpp@24: initialize: nvosdbin onscreen_display
2023-03-27 06:56:29.492 INFO  ./extensions/nvdsbase/tee.hpp@23: initialize: tee tee_1
2023-03-27 06:56:29.492 INFO  extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@24: initialize: nvvideorenderersinkbin video_renderer
2023-03-27 06:56:29.492 INFO  extensions/nvdscloudmsg/nvmsgbrokersinkbin.hpp@23: initialize: nvmsgbrokersinkbin Cloud Message Converter and Broker3
2023-03-27 06:56:29.492 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@27: initialize: nvstreammux streammux
2023-03-27 06:56:29.492 INFO  extensions/nvdsvisualization/nvtilerbin.hpp@37: initialize: nvtilerbin Video Tiler0
2023-03-27 06:56:29.492 INFO  gxf/gxe/gxe.cpp@256: Running...
2023-03-27 06:56:29.492 INFO  extensions/nvdsbase/nvds_scheduler.cpp@121: Scheduling 8 elements and 2 components
2023-03-27 06:56:29.492 INFO  extensions/nvdsinference/nvinferbin.hpp@32: create_element: nvinferbin object_detector
2023-03-27 06:56:29.550 INFO  extensions/nvdsinference/nvinferbin.hpp@56: bin_add: nvinferbin object_detector
2023-03-27 06:56:29.550 INFO  extensions/nvdsvisualization/nvosdbin.hpp@32: create_element: nvosdbin onscreen_display
2023-03-27 06:56:29.551 INFO  extensions/nvdsvisualization/nvosdbin.hpp@56: bin_add: nvosdbin onscreen_display
2023-03-27 06:56:29.551 INFO  ./extensions/nvdsbase/tee.hpp@31: create_element: tee tee_1
2023-03-27 06:56:29.551 INFO  ./extensions/nvdsbase/tee.hpp@55: bin_add: tee tee_1
2023-03-27 06:56:29.551 INFO  extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@32: create_element: nvvideorenderersinkbin video_renderer
2023-03-27 06:56:29.551 INFO  extensions/nvdsoutputsink/nvvideorenderersinkbin.hpp@54: bin_add: nvvideorenderersinkbin video_renderer
2023-03-27 06:56:29.551 INFO  extensions/nvdscloudmsg/nvmsgbrokersinkbin.hpp@31: create_element: nvmsgbrokersinkbin Cloud Message Converter and Broker3
2023-03-27 06:56:29.551 INFO  extensions/nvdscloudmsg/nvmsgbrokersinkbin.hpp@49: bin_add: nvmsgbrokersinkbin Cloud Message Converter and Broker3
2023-03-27 06:56:29.551 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@37: create_element: nvstreammux streammux
2023-03-27 06:56:29.552 INFO  extensions/nvdsmuxdemux/nvstreammux.hpp@61: bin_add: nvstreammux streammux
2023-03-27 06:56:29.552 INFO  extensions/nvdsvisualization/nvtilerbin.hpp@45: create_element: nvtilerbin Video Tiler0
2023-03-27 06:56:29.552 INFO  extensions/nvdsvisualization/nvtilerbin.hpp@69: bin_add: nvtilerbin Video Tiler0
2023-03-27 06:56:29.552 INFO  extensions/nvdssource/multi_uri_src_bin.cpp@343: create_element: NvDsMultiSrcInput Multi Source Input5
2023-03-27 06:56:29.552 INFO  extensions/nvdssource/multi_uri_src_bin.cpp@389: bin_add: bin Multi Source Input5
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /workspace/One/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine open error
0:00:04.952767192     1 0x7f3ca159be00 WARN                 nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 1]: deserialize engine from file :/workspace/One/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed
0:00:05.002643126     1 0x7f3ca159be00 WARN                 nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 1]: deserialize backend context from engine from file :/workspace/One/gxf/sample_models/primary.resnet10.caffemodel_b1_gpu0_int8.engine failed, try rebuild
0:00:05.002658181     1 0x7f3ca159be00 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 1]: Trying to create engine from model files
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
0:00:26.861477710     1 0x7f3ca159be00 INFO                 nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<nvinfer_bin_nvinfer> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1955> [UID = 1]: serialize cuda engine to file: /workspace/One/gxf/sample_models/primary.resnet10.caffemodel_b2_gpu0_int8.engine successfully
INFO: ../nvdsinfer/nvdsinfer_model_builder.cpp:610 [Implicit Engine Info]: layers num: 3
0   INPUT  kFLOAT input_1         3x368x640
1   OUTPUT kFLOAT conv2d_bbox     16x23x40
2   OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:26.915761485     1 0x7f3ca159be00 INFO                 nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<nvinfer_bin_nvinfer> [UID 1]: Load new model:/workspace/One/gxf/sample_models/config_infer_primary.txt sucessfully
Running...
****** NvDsScheduler Runtime Keyboard controls:
p: Pause pipeline
r: Resume pipeline
q: Quit pipeline
2023-03-27 06:56:55.941 INFO  extensions/nvdsbase/nvds_scheduler.cpp@398: NvDsScheduler Pipeline ready
2023-03-27 06:56:55.941 INFO  extensions/nvdsbase/nvds_scheduler.cpp@383: NvDsScheduler Pipeline running
Warning: Color primaries 5 not present and will be treated BT.601
2023-03-27 06:56:56.272 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin0/GstParseBin:aparsebin: Your GStreamer installation is missing a plug-in.
2023-03-27 06:56:56.272 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:
Source 0: Frame Number = 0 Total objects = 0 [ ]
Source 0: Frame Number = 1 Total objects = 0 [ ]
2023-03-27 06:56:56.419 ERROR extensions/nvdsbase/nvds_scheduler.cpp@312: Error from /GstPipeline:NvDsScheduler-Pipeline/GstBin:Multi Source Input/Multi Source Input5/GstDsNvUriSrcBin:dsnvurisrcbin1/GstParseBin:aparsebin: Your GStreamer installation is missing a plug-in.
2023-03-27 06:56:56.419 ERROR extensions/nvdsbase/nvds_scheduler.cpp@314: Debug info:
Source 0: Frame Number = 2 Total objects = 0 [ ]
Deleting pipeline
2023-03-27 06:56:56.586 INFO  gxf/gxe/gxe.cpp@278: Deinitializing...
2023-03-27 06:56:56.587 INFO  gxf/gxe/gxe.cpp@285: Destroying context
2023-03-27 06:56:56.587 INFO  gxf/gxe/gxe.cpp@291: Context destroyed.
Ok - I think I have found a solution - my IP cameras audio codec was set to was set to AAC - I switched them to PCM and now the container can run.
What are the audio codec limitations on the base containers? Locally the graph would run fine with the AAC codec - but in the container it would only work when I switched my cameras over to PCM?
PS - I think when I was running the single source container - I was just testing with an mp4 that comes with the demo app - that is why it was working - If I switched to my rtsp stream - the same issue occurred on the single source container.
What is your pipeline?
I don’t think It’s pipeline related - but related to the audio codec. We can close the issue for now. Thanks!
