Graph Composer v2.5 on Ubuntu 22.04 starts then stalls then fails
I am trying to run graph_composer-2.5.0_x86_64.deb on Ubuntu 22.04 running on VMWARE ESXi exposing a Tesla T4 GPU.
The GPU is exposed correctly to the Ubuntu VM and can be seen with nvidia-drivers nvidia-driver-525.78.01 installed.
I can start composer from the terminal and the UI comes up initially and then throws the following exception after approx 5 seconds.
This is reproducible via console/RDP/X.
Note. There is no sound card available to the ESXi server.
I appreciate any thoughts, fixes, workarounds or further details required.
Many thanks.
2023-02-16 10:29:56 [115,926ms] [Fatal] [carb.crashreporter-breakpad.plugin] Thread 424635 backtrace follows:
2023-02-16 10:29:56 [116,068ms] [Fatal] [carb.crashreporter-breakpad.plugin] 000: libc.so.6!__sigaction+0x50 (libc_sigaction.c:?)
2023-02-16 10:29:56 [116,203ms] [Fatal] [carb.crashreporter-breakpad.plugin] 001: libc.so.6!pthread_kill+0x12c (./nptl/pthread_kill.c:44)
2023-02-16 10:29:56 [116,332ms] [Fatal] [carb.crashreporter-breakpad.plugin] 002: libc.so.6!raise+0x16 (./signal/…/sysdeps/posix/raise.c:27)
2023-02-16 10:29:56 [116,461ms] [Fatal] [carb.crashreporter-breakpad.plugin] 003: libc.so.6!abort+0xd3 (./stdlib/abort.c:81 (discriminator 21))
2023-02-16 10:29:56 [116,545ms] [Fatal] [carb.crashreporter-breakpad.plugin] 004: libpulsecommon-15.99.so!pa_memblock_unref+0x175 (??:?)
2023-02-16 10:29:56 [116,632ms] [Fatal] [carb.crashreporter-breakpad.plugin] 005: libpulsecommon-15.99.so!pa_common_command_register_memfd_shmid+0x3a2 (??:?)
2023-02-16 10:29:56 [116,718ms] [Fatal] [carb.crashreporter-breakpad.plugin] 006: libpulsecommon-15.99.so!pa_pstream_register_memfd_mempool+0x303 (??:?)
2023-02-16 10:29:56 [116,805ms] [Fatal] [carb.crashreporter-breakpad.plugin] 007: libpulse.so.0!pa_mainloop_dispatch+0x270 (??:?)
2023-02-16 10:29:57 [116,892ms] [Fatal] [carb.crashreporter-breakpad.plugin] 008: libpulse.so.0!pa_mainloop_iterate+0x3a (??:?)
2023-02-16 10:29:57 [116,978ms] [Fatal] [carb.crashreporter-breakpad.plugin] 009: libcarb.audio-forge.plugin.so!std::mersenne_twister_engine<unsigned long, 32ul, 624ul, 397ul, 31ul, 2567483615ul, 11ul, 4294967295ul, 7ul, 2636928640ul, 15ul, 4022730752ul, 18ul, 1812433253ul>::operator()()+0x107886 (??:?)
