Graphic controller incompatible with Windows version
Hi, I installed the driver 416.34 WHQL for Windows 10 64 bit and when I open it it says “NVIDIA installer cannot continue. Graphic controller incompatible with Windows version”. What should I do?
Plus, I installed the other 2 required components, but I’m a bit lost. What should I do after I get this working? Cuase I’ve looked at the installing guide and have seen no command prompt or any way to open it.
Also, I have to say that my only puropose here is running the chess engine Leela Chess Zero in Arena.
Greetings
Personally I suggest you post the question on the appropriate forum that deals with hardware details. This is not a CUDA-related question, so people might simply ignore it.
