# Graphic problem: Linux-Kernel 6.8 - GeForce GT730 (nvidia-driver-470.256.02)
**URL:** <https://forums.developer.nvidia.com/t/graphic-problem-linux-kernel-6-8-geforce-gt730-nvidia-driver-470-256-02/309378>\
**Category:** Linux\
**Tags:** kernel, ubuntu\
**Created:** [October 10, 2024, 2:35pm UTC](https://forums.developer.nvidia.com/t/graphic-problem-linux-kernel-6-8-geforce-gt730-nvidia-driver-470-256-02/309378 "2024-10-10T14:35:14Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![generix](https://sea2.discourse-cdn.com/nvidia/user_avatar/forums.developer.nvidia.com/generix/32/16024_2.png) [@generix](https://forums.developer.nvidia.com/u/generix)\
**Post date:** [October 14, 2024, 1:20pm UTC](https://forums.developer.nvidia.com/t/graphic-problem-linux-kernel-6-8-geforce-gt730-nvidia-driver-470-256-02/309378/2 "2024-10-14T13:20:09Z")
</div>
If you used the distro packaged driver, there shouldn’t be any issue with the 470 driver and kernel 6.8. -But- installing kernel 6.8 from some random source on Mint 21 renders the kernel headers package incompatible to the Mint system so the nvidia driver won’t compile. You probably fell back to the fbdev driver in that case.
Mint 22 comes with kernel 6.8, so everything is compatible, the nvidia driver compiles. -but- AFAIK, Mint 22 changed to Wayland per default, so with the 470 nvidia driver, setting kernel parameter `nvidia_drm.modeset=1`
is needed for graphics to work.
_[View the full topic](https://forums.developer.nvidia.com/t/graphic-problem-linux-kernel-6-8-geforce-gt730-nvidia-driver-470-256-02/309378)._
