After upgrading to Nvidia 495.44 on my Arch Linux install, I am experiencing weird graphical glitches in Gnome Shell whenever I resume from sleep. It doesn’t appear every single resume, but it appears quite frequently enough to be bothersome. I can attach a screenshot the next time I encounter this issue.
I do have NVreg_PreserveVideoMemoryAllocations=1 turned on since I need it for Blender to work properly after resuming from sleep. If I turn it off, the corruption issue seems to not occur, at least as far as my personal testing goes, but then of course Blender totally breaks until I restart the program.
Currently, my workaround is to just hit Alt-F2 and type r into the run box to restart Gnome Shell, but having to do this every time is quite annoying.
I’ve already tried it with this fix. Graphical issues still exist after resume, but at least it properly resumes now instead of giving me a black screen like 21.1.2-1 did.
Thinking a bit more, this seems to trigger a memory… I can’t remember exactly where I saw this, but I think I saw a similar issue and it was related to an extension or system or shell theme (e.g. try Adwaita if you aren’t already using it).
I’m also experiencing graphics corruption (random squares) in applications after resuming from sleep. I use Gnome Xorg session (Wayland is broken for Optimus laptops) on Arch Linux.
I started experiencing this same problem several weeks ago with the 495.46 nvidia driver.
Yesterday, I installed some updates which included a new kernel (5.16.7-100) and a new version of the nvidia driver (510.47), and I’m still seeing the same corrupted graphics problem after a resume.
Anyone have any info on when a fix might be available? Is this a known problem that has been reported “properly”?
As per what generix suggested, I was having this issue on Fedora 35 with Gnome and XWin (rather than Wayland - because of the nvidia driver) and creating an /etc/modprobe.d/nvidia.conf and putting this line in it seems to have resolved it for me:
options nvidia NVreg_TemporaryFilePath=/var/tmp
Does having the correct (ACPI) kernel parameters set for your specific hardware platform help?
Example Only:
" acpi_osi=! acpi_osi=‘Windows 2020’ acpi_enforce_resources=lax acpi_sleep=s3_mode mem_sleep_default=deep numa=off iommu.forcedac=1 iommu=memaper "
