Hello, I’ve been running into an issue since starting Baldur’s Gate 3 where my screens will all randomly go black and require a reboot to reset. I mentioned this issue on the manjaro forums and one of the users saw a notice in the crash that mentioned reporting the bug here. That notice has not appeared in some of the more recent crashes, but I thought I’d still report here as nothing seems to fix the issue. I’ve attached the full crashlog, and the output of inxi -zv8 for system information.
Inxi output:
System:
Kernel:6.18.36-1-MANJAROarch:x86_64bits:64compiler:gccv:16.1.1
clocksource:tscavail:hpet,acpi_pm
parameters:BOOT_IMAGE=/boot/vmlinuz-6.18-x86_64
root=UUID=fc5d3333-e0e0-4a61-b871-66a87ed44af1 rw quiet splash
udev.log_priority=3
Desktop:KDE Plasmav:6.6.5tk:Qtv:N/Ainfo:frameworksv:6.27.0
wm:kwin_waylandvt:1dm:SDDMDistro:Manjarobase:Arch Linux
Machine:
Type:DesktopMobo:ASRockmodel:X570 Extreme4serial:<superuser required>
uuid:<superuser required>Firmware:UEFIvendor:American Megatrends
v:P5.80date:03/24/2026
Battery:
Message:No system battery data found. Is one present?
Memory:
System RAM: total:64 GiBavailable:62.72 GiBused:10.79 GiB (17.2%)
Message:For most reliable report, use superuser + dmidecode.
Array-1: capacity:128 GiBslots:4modules:4EC:None
max-module-size:32 GiBnote:est.
Device-1:Channel-A DIMM 0type:DDR4detail:synchronous unbuffered
(unregistered)size:16 GiBspeed:2667 MT/svolts: note:checkcurr:1
min:1max:1width (bits): data:64total:64manufacturer:G.Skill
part-no:F4-4000C18-16GTZRserial:N/A
Device-2:Channel-A DIMM 1type:DDR4detail:synchronous unbuffered
Device-3:Channel-B DIMM 0type:DDR4detail:synchronous unbuffered
Device-4:Channel-B DIMM 1type:DDR4detail:synchronous unbuffered
PCI Slots:
Permissions:Unable to run dmidecode. Root privileges required.
CPU:
Info: model:AMD Ryzen 7 5800Xbits:64type:MT MCParch:Zen 3+gen:3
level:v3note:checkbuilt:2022process:TSMC n6 (7nm)family:0x19 (25)
model-id:0x21 (33)stepping:0microcode:0xA201030
Topology: cpus:1xdies:1clusters:1cores:8threads:16tpc:2
smt:enabledcache: L1:512 KiBdesc:d-8x32 KiB; i-8x32 KiBL2:4 MiB
desc:8x512 KiBL3:32 MiBdesc:1x32 MiB
Speed (MHz): avg:4008min/max:556/4854boost:enabledscaling:
driver:amd-pstate-eppgovernor:powersavecores: 1:40082:40083:4008
4:40085:40086:40087:40088:40089:400810:400811:400812:4008
13:400814:400815:400816:4008bogomips:121374
Flags:3dnowprefetch abm adx aes aperfmperf apic arat avic avx avx2 bmi1
bmi2 bpext cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov cmp_legacy
constant_tsc cpb cpuid cqm cqm_llc cqm_mbm_local cqm_mbm_total
cqm_occup_llc cr8_legacy cx16 cx8 de debug_swap decodeassists erms
extapic extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt
ht hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
misalignsse mmx mmxext monitor movbe msr mtrr mwaitx nonstop_tsc nopl npt
nrip_save nx ospke osvw overflow_recov pae pat pausefilter pclmulqdq
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni
popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep
sha_ni skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3
stibp succor svm svm_lock syscall tce topoext tsc tsc_scale umip
user_shstk v_spec_ctrl v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
xsaves xtopology
Vulnerabilities:
Type:gather_data_samplingstatus:Not affected
Type:ghostwritestatus:Not affected
Type:indirect_target_selectionstatus:Not affected
Type:itlb_multihitstatus:Not affected
Type:l1tfstatus:Not affected
Type:mdsstatus:Not affected
Type:meltdownstatus:Not affected
Type:mmio_stale_datastatus:Not affected
Type:old_microcodestatus:Not affected
Type:reg_file_data_samplingstatus:Not affected
Type:retbleedstatus:Not affected
Type:spec_rstack_overflowmitigation:Safe RET
Type:spec_store_bypassmitigation:Speculative Store Bypass disabled via
prctl
Type:spectre_v1mitigation:usercopy/swapgs barriers and __user pointer
sanitization
Type:spectre_v2mitigation:Retpolines; IBPB: conditional; IBRS_FW;
STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type:srbdsstatus:Not affected
Type:tsamitigation:Clear CPU buffers
Type:tsx_async_abortstatus:Not affected
Type:vmscapemitigation:IBPB before exit to userspace
Graphics:
Device-1:NVIDIA GA104 [GeForce RTX 3070]vendor:ASUSTeKdriver:nvidia
v:610.43.02alternate:nouveau,nova_core,nvidia_drmnon-free:550-580.xx+
status:current (as of 2025-11; EOL~2026-12-xx)arch:Amperecode:GAxxx
process:TSMC n7 (7nm)built:2020-2023pcie: gen:4speed:16 GT/s
lanes:16ports: active:DP-1, DP-2, DP-3, HDMI-A-1empty:HDMI-A-2
bus-ID:0f:00.0chip-ID:10de:2484class-ID:0300
Device-2:Microdia PC-LM1Edriver:snd-usb-audio,uvcvideotype:USB
rev:2.0speed:480 Mb/slanes:1mode:2.0bus-ID:5-2:3chip-ID:0c45:636d
class-ID:0102serial:<filter>
Display:waylandserver:``X.org``v:1.21.1.23with:Xwaylandv:24.1.12
compositor:kwin_waylanddriver: X: loaded:nvidia
gpu:nv_platform,nvidia,nvidia-nvswitchd-rect:8720x4620display-ID:0
Monitor-1:DP-1pos:3-1model:Samsung LC34G55Tserial:<filter>
built:2022res: mode:3440x1440hz:100scale:100% (1)dpi:109gamma:1.2
chroma: red: x:0.651y:0.337green: x:0.310y:0.624blue: x:0.153
y:0.067white: x:0.306y:0.329size:798x334mm (31.42x13.15")
diag:869mm (34.2")modes:3440x1440, 2560x1440, 1920x1080, 1680x1050,
1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720, 1024x768,
800x600, 720x576, 720x480, 640x480
EDID-Warnings: 1:parse_edid: unknown tag 112
Monitor-2:DP-2pos:4-3model:Dell P2210serial:<filter>built:2011
res: mode:1680x1050hz:60scale:100% (1)dpi:90gamma:1.2chroma: red:
x:0.639y:0.329green: x:0.298y:0.600blue: x:0.149y:0.059white:
x:0.314y:0.329size:474x296mm (18.66x11.65")diag:559mm (22")
ratio:16:10modes:1680x1050, 1280x1024, 1152x864, 1024x768, 800x600,
640x480
Monitor-3:DP-3pos:2-4model:Dell P2210serial:<filter>built:2011
res: mode:1680x1050hz:60scale:160% (1.6)to:1050x1680dpi:90
gamma:1.2chroma: red: x:0.639y:0.329green: x:0.298y:0.600blue:
x:0.149y:0.059white: x:0.314y:0.329size:474x296mm (18.66x11.65")
diag:559mm (22")ratio:16:10modes:1680x1050, 1280x1024, 1152x864,
1024x768, 800x600, 640x480
Monitor-4:HDMI-A-1pos:1-2model:ViewSonic VA2231 Series
serial:<filter>built:2011res: mode:1920x1080hz:60scale:178% (1.78)
to:1080x1920dpi:102gamma:1.2chroma: red: x:0.639y:0.349green:
x:0.282y:0.620blue: x:0.141y:0.067white: x:0.314y:0.329
size:477x268mm (18.78x10.55")diag:547mm (21.5")ratio:16:9
modes:1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x960,
1280x800, 1152x864, 1024x768, 800x600, 640x480
API:EGLv:1.5hw: drv:nvidiaplatforms: gbm: drv:nvidiasurfaceless:
drv:nvidiawayland: drv:nvidiax11: drv:nvidia
API:OpenGLv:4.6.0vendor:nvidiav:610.43.02glx-v:1.4
direct-render:yesrenderer:NVIDIA GeForce RTX 3070/PCIe/SSE2
memory:7.81 GiBdisplay-ID::1.0
API:Vulkanv:1.4.350layers:9device:0type:discrete-gpu
name:NVIDIA GeForce RTX 3070driver:nvidiav:610.43.02
device-ID:10de:2484surfaces:N/A
Info: Tools: api:clinfo, eglinfo, glxinfo, vulkaninfo
de:kscreen-console,kscreen-doctorgpu:nvidia-settings,nvidia-smi
wl:wayland-infox11:xdpyinfo, xprop, xrandr
Audio:
Device-1:NVIDIA GA104 High Definition Audiovendor:ASUSTeK
driver:snd_hda_intelv:kernelpcie: gen:4speed:16 GT/slanes:16
bus-ID:0f:00.1chip-ID:10de:228bclass-ID:0403
Device-2:Advanced Micro Devices [AMD] Starship/Matisse HD Audio
vendor:ASRockdriver:snd_hda_intelv:kernelpcie: gen:4speed:16 GT/s
lanes:16bus-ID:11:00.4chip-ID:1022:1487class-ID:0403
Device-3:Texas Instruments PCM2902 Audio Codec
driver:hid-generic,snd-usb-audio,usbhidtype:USBrev:1.1speed:12 Mb/s
lanes:1mode:1.1bus-ID:5-1:2chip-ID:08bb:2902class-ID:0300
Device-4:Microdia PC-LM1Edriver:snd-usb-audio,uvcvideotype:USB
API:ALSAv:k6.18.36-1-MANJAROstatus:kernel-apiwith:aoss
type:oss-emulatortools:alsactl,alsamixer,amixer
Server-1:sndiodv:N/Astatus:offtools:aucat,midicat,sndioctl
Server-2:PipeWirev:1.6.6status:activewith: 1:pipewire-pulse
status:active2:wireplumberstatus:active3:pipewire-alsatype:plugin
4:pw-jacktype:plugintools:pactl,pw-cat,pw-cli,wpctl
Network:
Device-1:Intel I211 Gigabit Networkvendor:ASRockdriver:igbv:kernel
pcie: gen:1speed:2.5 GT/slanes:1port:f000bus-ID:08:00.0
chip-ID:8086:1539class-ID:0200
IF:enp8s0state:upspeed:1000 Mbpsduplex:fullmac:<filter>
IP v4:<filter>type:dynamic noprefixroutescope:global
broadcast:<filter>
IP v6:<filter>type:dynamic noprefixroutescope:global
IP v6:<filter>type:noprefixroutescope:link
Device-2:Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak]driver:iwlwifi
v:kernelpcie: gen:2speed:5 GT/slanes:1bus-ID:0a:00.0
chip-ID:8086:2725class-ID:0280
IF:wlp10s0state:upmac:<filter>
broadcast:<filter>
IF-ID-1:docker0state:downmac:<filter>
IP v4:<filter>scope:globalbroadcast:<filter>
Info: services:NetworkManager, sshd, systemd-networkd,
systemd-timesyncd, wpa_supplicant
WAN IP:<filter>
Bluetooth:
Device-1:Intel AX210 Bluetoothdriver:btusbv:0.8type:USBrev:2.0
speed:12 Mb/slanes:1mode:1.1bus-ID:3-6:3chip-ID:8087:0032
class-ID:e001
Report:btmgmtID:hci0rfk-id:0state:downbt-service:enabled,running
rfk-block: hardware:nosoftware:noaddress:<filter>bt-v:5.4lmp-v:13
status: discoverable:nopairing:no
Logical:
Message:Unable to run lvs. Root privileges required.
RAID:
Supported mdraid levels:raid1
Device-1:md127maj-min:9:127type:mdraidlevel:mirrorstatus:active
Info: report:2/2 UUblocks:3906886464chunk-size:N/Asuper-blocks:1.2
Components: Online:
0:sdamaj-min:8:0size:3.64 TiB
1:sdcmaj-min:8:32size:3.64 TiB
Drives:
Local Storage: total: raw:13.97 TiBusable:10.33 TiB
used:3.53 TiB (34.2%)
SMART Message:Unable to run smartctl. Root privileges required.
ID-1:/dev/nvme0n1maj-min:259:3model:XG7000-4TB 2280size:3.73 TiB
block-size: physical:512 Blogical:512 Bspeed:63.2 Gb/slanes:4
tech:SSDserial:<filter>fw-rev:SN19172temp:39.9 C
ID-2:/dev/nvme1n1maj-min:259:0vendor:Samsungmodel:SSD 990 PRO 2TB
size:1.82 TiBblock-size: physical:512 Blogical:512 Bspeed:63.2 Gb/s
lanes:4tech:SSDserial:<filter>fw-rev:4B2QJXD7temp:43.9 C
scheme:GPT
ID-3:/dev/sdamaj-min:8:0vendor:Seagatemodel:ST4000VN006-3CW104
size:3.64 TiBblock-size: physical:4096 Blogical:512 Bspeed:6.0 Gb/s
tech:HDDrpm:5400serial:<filter>fw-rev:SC60
SMART Message:Unknown smartctl error. Unable to generate data.
ID-4:/dev/sdbmaj-min:8:16vendor:OCZmodel:VERTEX4size:238.47 GiB
block-size: physical:512 Blogical:512 Bspeed:6.0 Gb/stech:SSD
serial:<filter>fw-rev:1.5scheme:MBR
ID-5:/dev/sdcmaj-min:8:32vendor:Seagatemodel:ST4000VN006-3CW104
ID-6:/dev/sddmaj-min:8:48vendor:Toshibamodel:MQ01ABD100
size:931.51 GiBblock-size: physical:4096 Blogical:512 Bspeed:6.0 Gb/s
tech:HDDrpm:5400serial:<filter>fw-rev:5Jscheme:GPT
Message:No optical or floppy data found.
Partition:
ID-1:/raw-size:1.82 TiBsize:1.79 TiB (98.37%)used:1.05 TiB (58.6%)
fs:ext4block-size:4096 Bdev:/dev/nvme1n1p2maj-min:259:2label:N/A
uuid:fc5d3333-e0e0-4a61-b871-66a87ed44af1
ID-2:/boot/efiraw-size:300 MiBsize:299.4 MiB (99.80%)
used:328 KiB (0.1%)fs:vfatblock-size:512 Bdev:/dev/nvme1n1p1
maj-min:259:1label:N/Auuid:1793-106E
ID-3:/run/media/june/Baksraw-size:2 TiBsize:2 TiB (99.95%)
used:1.75 TiB (87.5%)fs:xfsblock-size:512 Bdev:/dev/dm-1
maj-min:253:1mapped:vg_storage-lv_baklabel:N/Auuid:N/A
ID-4:/run/media/june/Dataraw-size:2 TiBsize:1.97 TiB (98.38%)
used:555.3 GiB (27.6%)fs:ext4block-size:4096 Bdev:/dev/dm-0
maj-min:253:0mapped:vg_storage_nvme-lv_datalabel:N/Auuid:N/A
ID-5:/run/media/june/RandomBaksraw-size:237.86 GiB
size:237.86 GiB (100.00%)used:178.66 GiB (75.1%)fs:ntfs
block-size:4096 Bdev:/dev/sdb2maj-min:8:18label:RandomBaks
uuid:008C06268C0616B6
ID-6:/run/media/june/VMsraw-size:931.51 GiBsize:931.06 GiB (99.95%)
used:17.86 GiB (1.9%)fs:xfsblock-size:512 Bdev:/dev/sdd1
maj-min:8:49label:VMsuuid:7b9cc68a-0956-4af7-98f8-be836e97f4d5
Swap:
Alert:No swap data was found.
Unmounted:
ID-1:/dev/sdb1maj-min:8:17size:100 MiBfs:ntfslabel:System Reserved
uuid:18A493B3A49391BC
ID-2:/dev/sdb3maj-min:8:19size:522 MiBfs:ntfslabel:N/A
uuid:AC1644DE1644AB62
USB:
Hub-1:1-0:1info:hi-speed hub with single TTports:6rev:2.0
speed:480 Mb/s (57.2 MiB/s)lanes:1mode:2.0chip-ID:1d6b:0002
class-ID:0900
Hub-2:1-2:2info:ASMedia ASM1074 High-Speed hubports:4rev:2.1
speed:480 Mb/s (57.2 MiB/s)lanes:1mode:2.0power:100mA
chip-ID:174c:2074class-ID:0900
Device-1:1-2.2:4info:QinHeng CH340 serial converter
type:<vendor specific>driver:ch341,ch341-uartinterfaces:1rev:1.1
speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1power:98mA
chip-ID:1a86:7523class-ID:ff00
Device-2:1-3:3info:Razer USA Chroma Addressable RGB Controller
type:HIDdriver:razeraccessory,usbhidinterfaces:3rev:2.0
speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1power:500mA
chip-ID:1532:0f1fclass-ID:0300
Hub-3:2-0:1info:super-speed hubports:4rev:3.1
speed:10 Gb/s (1.16 GiB/s)lanes:1mode:3.2 gen-2x1chip-ID:1d6b:0003
class-ID:0900
Hub-4:3-0:1info:hi-speed hub with single TTports:6rev:2.0
class-ID:0900
Device-1:3-5:2info:Razer USA Basilisk V3 Protype:mouse,keyboard
driver:razermouse,usbhidinterfaces:4rev:2.0speed:12 Mb/s (1.4 MiB/s)
lanes:1mode:1.1power:500mAchip-ID:1532:00aaclass-ID:0301
serial:<filter>
Device-2:3-6:3info:Intel AX210 Bluetoothtype:bluetoothdriver:btusb
interfaces:2rev:2.0speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1
power:100mAchip-ID:8087:0032class-ID:e001
Hub-5:4-0:1info:super-speed hubports:4rev:3.1
class-ID:0900
Hub-6:4-3:2info:ASMedia ASM1074 SuperSpeed hubports:4rev:3.0
speed:5 Gb/s (596.0 MiB/s)lanes:1mode:3.2 gen-1x1power:8mA
chip-ID:174c:3074class-ID:0900
Hub-7:5-0:1info:hi-speed hub with single TTports:4rev:2.0
class-ID:0900
Device-1:5-1:2info:Texas Instruments PCM2902 Audio Codec
type:audio,HIDdriver:hid-generic,snd-usb-audio,usbhidinterfaces:4
rev:1.1speed:12 Mb/s (1.4 MiB/s)lanes:1mode:1.1power:100mA
Device-2:5-2:3info:Microdia PC-LM1Etype:video,audio
driver:snd-usb-audio,uvcvideointerfaces:4rev:2.0
speed:480 Mb/s (57.2 MiB/s)lanes:1mode:2.0power:500mA
chip-ID:0c45:636dclass-ID:0102serial:<filter>
Device-3:5-3:4info:Razer USA BlackWidow V4 Protype:keyboard,mouse,HID
driver:razerkbd,usbhidinterfaces:5rev:2.0speed:480 Mb/s (57.2 MiB/s)
lanes:1mode:2.0power:500mAchip-ID:1532:028dclass-ID:0300
Hub-8:5-4:5info:Genesys Logic Hubports:4rev:2.0
chip-ID:05e3:0610class-ID:0900
Device-1:5-4.4:6info:Razer USA Firefly V2 Protype:mouse,keyboard
chip-ID:1532:0c08class-ID:0300
Hub-9:6-0:1info:super-speed hubports:4rev:3.1
class-ID:0900
Sensors:
System Temperatures: cpu:36.5 Cmobo:36.0 C
Fan Speeds (rpm): fan-1:1222fan-2:0fan-3:3982fan-4:0fan-5:1222
fan-7:947
Repos:
Packages:2087pm:pacmanpkgs:2066libs:537tools:pamac,yaypm:rpm
pkgs:0pm:flatpakpkgs:21
Active pacman repo servers in:/etc/pacman.d/mirrorlist
1: https://mirrors.manjaro.org/repo/stable/$repo/$arch``
2: https://muug.ca/mirror/manjaro/stable/$repo/$arch``
3: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch``
4: https://distrohub.kyiv.ua/manjaro/stable/$repo/$arch``
5: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch``
Processes:
CPU top:5 of 465
1: cpu:14.5%command:konsolepid:12978mem:232.7 MiB (0.3%)
2: cpu:12.1%command:vesktoppid:8708mem:629.0 MiB (0.9%)
3: cpu:11.6%command:thumbnail.sostarted-by:kioworkerpid:13082
mem:160.2 MiB (0.2%)
4: cpu:10.4%command:thumbnail.sostarted-by:kioworkerpid:13084
mem:162.0 MiB (0.2%)
5: cpu:7.5%command:zshpid:12991mem:10.8 MiB (0.0%)
Memory top:5 of 465
1: mem:814.2 MiB (1.2%)command:python3pid:10643cpu:1.0%
2: mem:724.2 MiB (1.1%)command:bravepid:8358cpu:5.2%
3: mem:696.0 MiB (1.0%)command:plasmashellpid:1909cpu:1.0%
4: mem:629.0 MiB (0.9%)command:vesktoppid:8708cpu:12.1%
5: mem:537.6 MiB (0.8%)command:bravepid:8458cpu:1.7%
Info:
Processes:465Power: uptime:23mstates:freeze,mem,disksuspend:deep
avail:s2idlewakeups:0hibernate:platformavail:shutdown, reboot,
suspend, test_resumeimage:25 GiBservices:org_kde_powerdevil,
power-profiles-daemon, upowerdInit:systemdv:260default:graphical
tool:systemctl
Compilers: clang:22.1.6gcc:16.1.1Shell:Zshv:5.9.1default:Bash
v:5.3.15running-in:konsoleinxi: 3.3.40
Crash log:
journalctl.txt (3.7 MB)
