Grid Director 2012--The switch you've logged in is not the master SM Would you like to connect to the master SM switch?
When I use SSH to log on to Director Grid 2012, it will make the following tips:
"The switch you’ve logged in is not the master SM
Would you like to connect to the master SM switch? [yes|no]"
System version of the device is: “5.4.0 version
I check the SM status, the information is as follows:
L:ISR2012-2c6c(config-sm)# sm-info show
subnet manager info is:
smName= ISR2012-2c6c
port guid= 0008f10400402c6f
topology= none
active topology= none
algorithm= balanced-routing
active algorithm= balanced-routing
sm KEY = 0000000000000000
sm priority = 13
actual-sm-priority = 13
sm sweep interval (seconds)= 15
sm verbosity mode = verbose
sm topology verbosity = none
sm mads-pipeline = 16
sm polling-retries = 3
sm activity = 37946
sm state = standby
sm mode = enable
sm LMC = 7
sm hoq = 16
sm slv = 3
sm mopvl = vl0-14
subnet-prefix = 0xfe80000000000000
port-state-change-trap = enable
bad ports mode = enable
pm mode = enable
grouping mode = enable
sm low-lid-boundary = 1
sm high-lid-boundary = 49151
sm m_key seed = 0000000000000000 [0 disable]
sm m_key lease period = 30 [sec]
PS: the device is running, only use the IB cable to connect to the server’s HCA card, how will the state of SM into Master state?
If anyone has any suggestions, bother to send to my email: 282655008@qq.com mailto:282655008@qq.com , thank you!
hi 惠锋 方, https://community.mellanox.com/s/profile/0051T000008EZwbQAG
We can assume that the question/issue is answered/resolved?
maybe there is another SM running with a higher priority…
what does the output of “saquery -s” show (please run from a server connceted to the IB network).
this command shows all fabric ports running SM and their priorities
