yes, for the package manager method, you would install the cuda-toolkit
meta package, instead of cuda
for the runfile installer, there is a command line switch. I forget the exact syntax and it changes from time to time. Use --help to get command line help for the runfile installer.
These items are covered in the CUDA linux install guide. You’ll want to pay attention to versions. Make sure whatever CUDA toolkit you are installing is compatible with whatever driver you have installed. Also, not all grid instances support CUDA. See here and here. Detailed grid questions may be asked on the grid forums.
