Output from Openstack Server?not the vm:
[root@localhost libvirt]# lspci -vvvv -d "10de:*" | grep Region
Region 0: Memory at 94000000 (32-bit, non-prefetchable)
Region 1: Memory at 33ff0000000 (64-bit, prefetchable)
Region 3: Memory at 33ff8000000 (64-bit, prefetchable)
Region 5: I/O ports at 5000
Region 0: Memory at 93000000 (32-bit, non-prefetchable)
Region 1: Memory at 33fe0000000 (64-bit, prefetchable)
Region 3: Memory at 33fe8000000 (64-bit, prefetchable)
Region 5: I/O ports at 4000
Region 0: Memory at 92000000 (32-bit, non-prefetchable)
Region 1: Memory at 33fd0000000 (64-bit, prefetchable)
Region 3: Memory at 33fd8000000 (64-bit, prefetchable)
Region 5: I/O ports at 3000
Region 0: Memory at 91000000 (32-bit, non-prefetchable)
Region 1: Memory at 33fc0000000 (64-bit, prefetchable)
Region 3: Memory at 33fc8000000 (64-bit, prefetchable)
Region 5: I/O ports at 2000
One thing I can not understand is k1 passed to vm.so the command lspci should be executed on vm or the openstack server?
