GRID K1 with horizon view 6.01 not loading all vm's
I have recently installed the latest version 352.54. But i can see that my VDI’s that is build from scratch are not loaded, they all have 1mb? But my older vm’s (RPCxxx) looks ok. Why? Are there any configurations on the vm? My pool configuration on RPC and VDI are the same…
| NVIDIA-SMI 352.54 Driver Version: 352.54 |
| 0 GRID K1 Off | 0000:06:00.0 Off | N/A |
| N/A 31C P8 9W / 31W | 264MiB / 4095MiB | 22% Default |
| 1 GRID K1 Off | 0000:07:00.0 Off | N/A |
| N/A 30C P8 7W / 31W | 41MiB / 4095MiB | 0% Default |
| 2 GRID K1 Off | 0000:08:00.0 Off | N/A |
| N/A 24C P8 9W / 31W | 635MiB / 4095MiB | 20% Default |
| 3 GRID K1 Off | 0000:09:00.0 Off | N/A |
| N/A 28C P8 7W / 31W | 103MiB / 4095MiB | 0% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 35899 G 7MiB |
| 0 118711 G RPC009 /bin/vmx 223MiB |
| 0 548685 G VDI004 /bin/vmx 1MiB |
| 0 581471 G VDI001 /bin/vmx 1MiB |
| 0 847846 G VDI029 /bin/vmx 1MiB |
| 0 860031 G VDI036 /bin/vmx 1MiB |
| 0 940264 G VDI046 /bin/vmx 1MiB |
| 0 945771 G VDI059 /bin/vmx 1MiB |
| 0 948274 G VDI072 /bin/vmx 1MiB |
| 0 951702 G VDI083 /bin/vmx 1MiB |
| 0 953807 G VDI095 /bin/vmx 1MiB |
| 0 957998 G VDI119 /bin/vmx 1MiB |
| 0 959426 G VDI023 /bin/vmx 1MiB |
| 0 960380 G VDI129 /bin/vmx 1MiB |
| 0 963804 G VDI143 /bin/vmx 1MiB |
| 0 971254 G VDI105 /bin/vmx 1MiB |
| 1 36069 G 6MiB |
| 1 581359 G VDI011 /bin/vmx 1MiB |
| 1 731510 G VDI008 /bin/vmx 1MiB |
| 1 932876 G VDI007 /bin/vmx 1MiB |
| 1 938849 G VDI040 /bin/vmx 1MiB |
| 1 945559 G VDI028 /bin/vmx 1MiB |
| 1 946655 G VDI062 /bin/vmx 1MiB |
| 1 948833 G VDI075 /bin/vmx 1MiB |
| 1 951864 G VDI084 /bin/vmx 1MiB |
| 1 952485 G VDI033 /bin/vmx 1MiB |
| 1 955911 G VDI106 /bin/vmx 1MiB |
| 1 958043 G VDI120 /bin/vmx 1MiB |
| 1 961082 G VDI074 /bin/vmx 1MiB |
| 1 964235 G VDI144 /bin/vmx 1MiB |
| 1 972622 G VDI096 /bin/vmx 1MiB |
| 1 972703 G VDI052 /bin/vmx 1MiB |
| 2 36263 G 7MiB |
| 2 121026 G RPC004 /bin/vmx 306MiB |
| 2 133167 G RPC022 /bin/vmx 156MiB |
| 2 161726 G RPC027 /bin/vmx 144MiB |
| 2 581692 G VDI019 /bin/vmx 1MiB |
| 2 701280 G VDI037 /bin/vmx 1MiB |
| 2 939080 G VDI042 /bin/vmx 1MiB |
| 2 947321 G VDI069 /bin/vmx 1MiB |
| 2 952579 G VDI087 /bin/vmx 1MiB |
| 2 954400 G VDI100 /bin/vmx 1MiB |
| 2 956340 G VDI111 /bin/vmx 1MiB |
| 2 958423 G VDI123 /bin/vmx 1MiB |
| 2 960906 G VDI132 /bin/vmx 1MiB |
| 2 961612 G VDI135 /bin/vmx 1MiB |
| 2 964986 G VDI147 /bin/vmx 1MiB |
| 2 970677 G VDI056 /bin/vmx 1MiB |
| 3 36431 G 7MiB |
| 3 581627 G VDI017 /bin/vmx 1MiB |
| 3 581755 G VDI022 /bin/vmx 1MiB |
| 3 793527 G VDI003 /bin/vmx 1MiB |
| 3 823899 G VDI101 /bin/vmx 1MiB |
| 3 838504 G VDI126 /bin/vmx 1MiB |
| 3 940039 G VDI045 /bin/vmx 1MiB |
| 3 945079 G VDI058 /bin/vmx 1MiB |
| 3 947855 G VDI071 /bin/vmx 1MiB |
| 3 949224 G RPC008 /bin/vmx 62MiB |
| 3 952412 G VDI002 /bin/vmx 1MiB |
| 3 952804 G VDI006 /bin/vmx 1MiB |
| 3 953023 G VDI090 /bin/vmx 1MiB |
| 3 957132 G VDI114 /bin/vmx 1MiB |
| 3 963745 G VDI141 /bin/vmx 1MiB |
| 3 965905 G VDI150 /bin/vmx 1MiB |
Can you show a screenshot of the VM configurations?
Wich configuration do you mean? What i ment was do i have to install drivers on image golden image also? I am going to try to uninstal the vmtools and view agent and install them again starting with vmtools and then view agent.
If you’re using vSGA, the best place to ask questions on that is VMware as it’s not an Nvidia solution.
The general config looks OK, but you may need to do a little matching up of versions in ESX, .vib and the VM Tools.
