Our organisation is starting to use Azure servers to stream apps and create virtual desktops. We are running Azure Nv12v3’s with the M60 cards in them. As part of the agreement with Microsoft we get Grid licences for every GPU.
Grid des not seem to be working though. We are running an App called keyshot 9.3 that can render using GPU’s. but Grid does not share the processing equally like I believe it should. one guest/user on the VM will dominate the card while the other users on the machine will get virtually no GPU access.
Please can you advise what the issue might be.
Kind Regards
Simon
