I created Gripper object that inherits from the parallelgripper superclass, and imported the Gripper via URDF importer, however when I see the Gripper on isaacsim, Gripper is not attached to the Robot end-effector ! can you please tell me how I can attach the Gripper to the End-Effector Properly? thanks.
I want to assemble the robot with the Gripper similar to here where both of them are imported using the URDF importer, and both inherits superclasses: Robot, Gripper from isaacsim api.
class Robotiq2F140(ParallelGripper):
def __init__(
self,
gripper_name: str,
urdf_path: str,
end_effector_prim_path: str,
joint_prim_names: List[str],
joint_opened_positions: np.ndarray,
joint_closed_positions: np.ndarray,
app: SimulationApp,
*args, **kwargs
) -> None:
self._gripper_name = gripper_name
self._end_effector_prim_path = end_effector_prim_path
self._joint_prim_names = joint_prim_names
self._joint_opened_positions = joint_opened_positions
self._joint_closed_positions = joint_closed_positions
self.robot_prim_path = self._import_gripper(urdf_path)
self._app = app
super().__init__(
end_effector_prim_path=self._end_effector_prim_path,
joint_prim_names = self._joint_prim_names,
joint_opened_positions = self._joint_opened_positions,
joint_closed_positions = self._joint_closed_positions,
*args, **kwargs
def _import_gripper(self, urdf_path: str) -> str:
# Set the settings in the import config
import_config = _urdf.ImportConfig()
import_config.set_merge_fixed_joints(False)
import_config.set_convex_decomp(True) # Collision
import_config.set_fix_base(True)
import_config.set_make_default_prim(False)
import_config.set_self_collision(True) #
import_config.set_create_physics_scene(False)
import_config.set_import_inertia_tensor(False) #
import_config.set_default_drive_type(_urdf.UrdfJointTargetType.JOINT_DRIVE_POSITION)
status, self._gripper_prim_path = omni.kit.commands.execute(
"URDFParseAndImportFile",
urdf_path=urdf_path,
import_config=import_config,
get_articulation_root=False,
if not status:
raise RuntimeError("Failed to import URDF file.")
Isaac Sim Version
4.5.0
Operating System
Ubuntu 22.04
GPU Information
- Model: GeForce RTX 2070
- Driver Version: 550.127.08
