I have Nvidia Geforce GTX1080 (8gb) installed in my workstation along with NVCC (CUDA 9.1) version: 9.1.85. I am trying to build and install Gromcas 5.1.5 using following sequence. However I am getting error as mentioned below. Could you please help to resolve the problem.
Cmake command to generate build files was successful:
cmake … -DGMX_BUILD_OWN_FFTW=ON -DREGRESSIONTEST_DOWNLOAD=ON -DGMX_GPU=on -DGMX_BUILD_MDRUN_ONLY=on -DGMX_BINARY_SUFFIX=_cuda -DGMX_LIBS_SUFFIX=_cuda -DCUDA_TOOLKIT_ROOT_DIR=/usr/local/cuda-9.1
ERROR FROM make:
Making install in m4
[ 0%] Completed ‘fftwBuild’
[ 0%] Built target fftwBuild
[ 0%] Generating baseversion-gen.c
[ 1%] Building NVCC (Device) object src/gromacs/CMakeFiles/libgromacs.dir/gmxlib/cuda_tools/libgromacs_generated_copyrite_gpu.cu.o
nvcc fatal : Unsupported gpu architecture ‘compute_20’
CMake Error at libgromacs_generated_copyrite_gpu.cu.o.cmake:207 (message):
Error generating
/home/joydeep/Downloads/gromacs-5.1.5/build/src/gromacs/CMakeFiles/libgromacs.dir/gmxlib/cuda_tools/./libgromacs_generated_copyrite_gpu.cu.o
src/gromacs/CMakeFiles/libgromacs.dir/build.make:63: recipe for target ‘src/gromacs/CMakeFiles/libgromacs.dir/gmxlib/cuda_tools/libgromacs_generated_copyrite_gpu.cu.o’ failed
make[2]: *** [src/gromacs/CMakeFiles/libgromacs.dir/gmxlib/cuda_tools/libgromacs_generated_copyrite_gpu.cu.o] Error 1
CMakeFiles/Makefile2:1291: recipe for target ‘src/gromacs/CMakeFiles/libgromacs.dir/all’ failed
make[1]: *** [src/gromacs/CMakeFiles/libgromacs.dir/all] Error 2
Makefile:160: recipe for target ‘all’ failed
make: *** [all] Error 2
Thanks in advance…
