on using this command “pip install ../../proto/sample_wheel/nvidia_ace-1.2.0-py3-none-any.whl” for audio2face setup i am getting this error :
grpc_root\src/compiler/python_generator_helpers.h(104): warning C4267: ‘initializing’: conversion from ‘size_t’ to ‘const int’, possible loss of data
grpc_root\src\compiler\python_generator.cc(852): warning C4267: ‘argument’: conversion from ‘size_t’ to ‘int’, possible loss of data
grpc_root\src\compiler\python_generator.cc(893): warning C4267: ‘initializing’: conversion from ‘size_t’ to ‘int’, possible loss of data
grpc_root\src\compiler\python_generator.cc(893): warning C4267: ‘initializing’: conversion from ‘size_t’ to ‘const int’, possible loss of data
“E:\Software\visual studio 2022 software\VC\Tools\MSVC\14.41.34120\bin\HostX86\x64\cl.exe” /c /nologo /O2 /W3 /GL /DNDEBUG /MD -DWIN32_LEAN_AND_MEAN=1 -DNOMINMAX=1 -DMS_WIN64=1 -I. -Igrpc_root -Igrpc_root\include -Ithird_party\abseil-cpp -Ithird_party\protobuf\src -Ithird_party\protobuf\third_party\utf8_range “-IF:\Office IMP docs\Projects docs\ZS\R&D\nvidia audio2face.venv\include” -IC:\Users\saura\AppData\Local\Programs\Python\Python313\include -IC:\Users\saura\AppData\Local\Programs\Python\Python313\Include “-IE:\Software\visual studio 2022 software\VC\Tools\MSVC\14.41.34120\include” “-IE:\Software\visual studio 2022 software\VC\Auxiliary\VS\include” “-ID:\Windows Kits\10\include\10.0.22621.0\ucrt” “-ID:\Windows Kits\10\include\10.0.22621.0\um” “-ID:\Windows Kits\10\include\10.0.22621.0\shared” “-ID:\Windows Kits\10\include\10.0.22621.0\winrt” “-ID:\Windows Kits\10\include\10.0.22621.0\cppwinrt” “-IC:\Program Files (x86)\Windows Kits\NETFXSDK\4.8\include\um” /EHsc /Tpgrpc_tools_protoc_compiler.cpp /Fobuild\temp.win-amd64-cpython-313\Release\grpc_tools_protoc_compiler.obj /std:c11 /MT
cl : Command line warning D9025 : overriding ‘/MD’ with ‘/MT’
C:\Users\saura\AppData\Local\Programs\Python\Python313\include\pyconfig.h(138): warning C4005: ‘MS_WIN64’: macro redefinition
C:\Users\saura\AppData\Local\Programs\Python\Python313\include\pyconfig.h(138): note: ‘MS_WIN64’ previously declared on the command line
grpc_tools_protoc_compiler.cpp(1190): warning C4996: ‘Py_UNICODE’: deprecated in 3.13
grpc_tools_protoc_compiler.cpp(1191): warning C4996: ‘Py_UNICODE’: deprecated in 3.13
grpc_tools_protoc_compiler.cpp(2307): warning C4244: ‘argument’: conversion from ‘Py_ssize_t’ to ‘int’, possible loss of data
grpc_tools_protoc_compiler.cpp(6401): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6413): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6425): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6464): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6476): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6493): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6536): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6548): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6560): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(6572): error C3861: ‘_PyDict_SetItem_KnownHash’: identifier not found
grpc_tools_protoc_compiler.cpp(8815): error C2660: ‘_PyLong_AsByteArray’: function does not take 5 arguments
C:\Users\saura\AppData\Local\Programs\Python\Python313\include\cpython/longobject.h(111): note: see declaration of ‘_PyLong_AsByteArray’
grpc_tools_protoc_compiler.cpp(8815): note: while trying to match the argument list ‘(PyLongObject *, unsigned char *, size_t, int, bool)’
grpc_tools_protoc_compiler.cpp(9049): error C2660: ‘_PyLong_AsByteArray’: function does not take 5 arguments
grpc_tools_protoc_compiler.cpp(9049): note: while trying to match the argument list ‘(PyLongObject *, unsigned char *, size_t, int, bool)’
grpc_tools_protoc_compiler.cpp(9245): error C2660: ‘_PyLong_AsByteArray’: function does not take 5 arguments
grpc_tools_protoc_compiler.cpp(9245): note: while trying to match the argument list ‘(PyLongObject *, unsigned char *, size_t, int, bool)’
grpc_tools_protoc_compiler.cpp(9833): error C3861: ‘_PyGen_SetStopIterationValue’: identifier not found
error: command ‘E:\Software\visual studio 2022 software\VC\Tools\MSVC\14.41.34120\bin\HostX86\x64\cl.exe’ failed with exit code 2
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for grpcio_tools
Running setup.py clean for grpcio_tools
Failed to build grpcio_tools
