Hi
We get GSP panic issue when using AGX ORIN Jetpack R36.4.4
Apr 16 10:48:28 chassis kernel: [ 5263.860510] nvethernet 6800000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Apr 16 10:59:43 chassis kernel: [ 5939.127371] nvethernet 6800000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Apr 16 11:00:05 chassis kernel: [ 5961.365189] nvgpu: 17000000.gpu gsp_sched_wait_for_init:110 [ERR] gsp wait for init timedout
Apr 16 11:00:05 chassis kernel: [ 5961.365283] nvgpu: 17000000.gpu nvgpu_gsp_sched_bootstrap_hs:209 [ERR] gsp wait for basic init failed
Apr 16 11:00:05 chassis kernel: [ 5961.365344] nvgpu: 17000000.gpu nvgpu_finalize_poweron:1095 [ERR] Failed initialization for: &nvgpu_gsp_sched_bootstrap_hs
Apr 16 11:00:05 chassis kernel: [ 5961.526290] nvethernet 6800000.ethernet: config.flags = 0x0, tx_type = 0x1,rx_filter = 0xc
Apr 16 11:00:22 chassis kernel: [ 5978.353166] thermal cooling_device12: hot-surface-alert cooling state: 1 → 0
Apr 16 11:00:28 chassis kernel: [ 5984.576704] rcu: INFO: rcu_preempt self-detected stall on CPU
Apr 16 11:00:28 chassis kernel: [ 5984.576711] rcu: 0-…: (5249 ticks this GP) idle=63f/1/0x4000000000000002 softirq=1057721/1082275 fqs=2328
Apr 16 11:00:28 chassis kernel: [ 5984.576717] (t=5250 jiffies g=1303105 q=309526)
Apr 16 11:00:28 chassis kernel: [ 5984.576720] Task dump for CPU 0:
Apr 16 11:00:28 chassis kernel: [ 5984.576721] task:irq/208-gk20a_s state:R running task stack: 0 pid: 361 ppid: 2 flags:0x0000000a
Apr 16 11:00:28 chassis kernel: [ 5984.576726] Call trace:
Apr 16 11:00:28 chassis kernel: [ 5984.576727] dump_backtrace+0x0/0x1d0
Apr 16 11:00:28 chassis kernel: [ 5984.576738] show_stack+0x34/0x50
Apr 16 11:00:28 chassis kernel: [ 5984.576741] sched_show_task+0x17c/0x1b0
Apr 16 11:00:28 chassis kernel: [ 5984.576746] dump_cpu_task+0x50/0x68
Apr 16 11:00:28 chassis kernel: [ 5984.576750] rcu_dump_cpu_stacks+0xf4/0x140
Apr 16 11:00:28 chassis kernel: [ 5984.576753] rcu_sched_clock_irq+0xc9c/0xef0
Apr 16 11:00:28 chassis kernel: [ 5984.576755] update_process_times+0xa8/0xf0
Apr 16 11:00:28 chassis kernel: [ 5984.576759] tick_sched_handle+0x4c/0x80
Apr 16 11:00:28 chassis kernel: [ 5984.576760] tick_sched_timer+0x58/0xc0
Apr 16 11:00:28 chassis kernel: [ 5984.576762] __hrtimer_run_queues+0x184/0x360
Apr 16 11:00:28 chassis kernel: [ 5984.576764] hrtimer_interrupt+0xf4/0x240
Apr 16 11:00:28 chassis kernel: [ 5984.576766] arch_timer_handler_phys+0x44/0x70
Apr 16 11:00:28 chassis kernel: [ 5984.576770] handle_percpu_devid_irq+0x94/0x260
Apr 16 11:00:28 chassis kernel: [ 5984.576773] handle_domain_irq+0x74/0xc0
Apr 16 11:00:28 chassis kernel: [ 5984.576774] gic_handle_irq+0x68/0x170
Apr 16 11:00:28 chassis kernel: [ 5984.576778] call_on_irq_stack+0x20/0x50
Apr 16 11:00:28 chassis kernel: [ 5984.576780] do_interrupt_handler+0x78/0xa0
Apr 16 11:00:28 chassis kernel: [ 5984.576782] el1_interrupt+0x30/0x70
Apr 16 11:00:28 chassis kernel: [ 5984.576785] el1h_64_irq_handler+0x18/0x30
Apr 16 11:00:28 chassis kernel: [ 5984.576787] el1h_64_irq+0x7c/0x80
Apr 16 11:00:28 chassis kernel: [ 5984.576788] queued_spin_lock_slowpath+0x264/0x3a0
Apr 16 11:00:28 chassis kernel: [ 5984.576791] _raw_spin_lock+0x9c/0xc0
Apr 16 11:00:28 chassis kernel: [ 5984.576792] __mutex_lock.constprop.0+0xa4/0x600
Apr 16 11:00:28 chassis kernel: [ 5984.576795] __mutex_lock_slowpath+0x2c/0x50
Apr 16 11:00:28 chassis kernel: [ 5984.576797] mutex_lock+0x84/0xa0
Apr 16 11:00:28 chassis kernel: [ 5984.576800] nvgpu_gsp_isr_mutex_acquire+0x28/0x40 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.576890] ga10b_gsp_isr+0xc0/0x410 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.576954] nvgpu_gsp_sched_isr+0x34/0x50 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.577015] nvgpu_gsp_isr+0x38/0x60 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.577075] ga10b_intr_isr_stall+0x660/0x970 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.577134] nvgpu_cic_mon_intr_stall_handle+0x48/0xa0 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.577193] __traceiter_gk20a_cde_finished_ctx_cb+0x1098/0x1310 [nvgpu]
Apr 16 11:00:28 chassis kernel: [ 5984.577251] irq_thread_fn+0x38/0xd0
Apr 16 11:00:28 chassis kernel: [ 5984.577254] irq_thread+0x1ac/0x320
Apr 16 11:00:28 chassis kernel: [ 5984.577256] kthread+0x184/0x1a0
Apr 16 11:00:28 chassis kernel: [ 5984.577257] ret_from_fork+0x10/0x20
bootlog_33.log (143.9 KB)
