My platform is GPU and I am using DeepStream 6.1 with 8.2.5 TensorRT. Driver Version: 510.85.02
I used gstdsexample_optimized.cpp to save images of the detected objects, however when there is more than one detected object in the same frame plugin only save the one of them. Is there any way to save all cropped images as a batch form.
And how the solution can be extended to work with more than one stream.
did you still need support? from your link code, need to add object id in IMpath .
IMpath = IMpath + std::to_string(dsexample->frame_num) +“_new” + “.jpg”;
please refer to gstdsexample.cpp code below DSEXAMPLE_DEBUG.
There is no update from you for a period, assuming this is not an issue any more. Hence we are closing this topic. If need further support, please open a new one. Thanks
