Gst-launch-1.0 didn't use video1 but I was told that opening vedio1 failed
TX2 NX Jetpack 4.6.3
:~$ gst-launch-1.0 v4l2src device=/dev/video0 ! nvvideoconvert ! nvvideoconvert ! nvv4l2h264enc ! decodebin ! nvvideoconvert ! ‘video/x-raw, width=320, height=240’ ! v4l2sink device=/dev/video12
Setting pipeline to PAUSED …
Failed to open /dev/video1: No such file or directory
Failed to open /dev/video2: No such file or directory
Failed to open /dev/video3: No such file or directory
Failed to open /dev/video4: No such file or directory
Failed to open /dev/video5: No such file or directory
Failed to open /dev/video6: No such file or directory
Failed to open /dev/video7: No such file or directory
Failed to open /dev/video8: No such file or directory
Failed to open /dev/video9: No such file or directory
Failed to open /dev/video10: No such file or directory
Failed to open /dev/video11: No such file or directory
Opening in BLOCKING MODE
ArgusV4L2_Open failed: No such file or directory
libv4l2: error getting pixformat: Invalid argument
Pipeline is live and does not need PREROLL …
Setting pipeline to PLAYING …
New clock: GstSystemClock
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Redistribute latency…
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
NVMEDIA_ENC: bBlitMode is set to TRUE
For running v4l2loopback, please try this setup:
Gstreamer v4l2loopback hw mjpeg stream - #5 by Honey_Patouceul
Not sure if Failed to open /dev/video1: No such file or directory is a warning or an issue. It looks like the pipeline is running although the prints show up.
With the warning prints we can know there’s empty video nodese. You can set to first empty node to avoid the prints.
Thank you for reply! I have other questions about this directive, and I will open up a new topic.
