Gst-launch-1.0 -vv alsasrc ! alsasink does not work in docker
hi
thanks for your help
We have solve this issue last week!
ths!
hi
# apt update
# apt install alsa-base alsa-utils pulseaudio
You would need to install the packages every time of launching docker.
------can I add  alsa-base alsa-utils pulseaudio into Dockerfile and I don'
t want to install this package every time in docker.
We do some search and don’t see much information about including the audio-related files into docker. Ideally it should work if you can add all files/directories into l4t.csv. But may need to investigate which files/directories are required.
Probably a quick solution is to collect all commands into a script and you can execute the script at very beginning of entering docker.
