gstnvcompositor.c: In function ‘gst_nvcompositor_pad_prepare_frame’:
gstnvcompositor.c:548:11: error: ‘GstVideoAggregatorPad {aka struct _GstVideoAggregatorPad}’ has no member named ‘buffer’
if (!pad->buffer)
Since the plugins are built with 1.14.5, it may not work properly with other version which has deviation in header files. We would suggest use 1.14.5.
On r32 releases, the gstreamer version stays on 1.14.5 and there is no plan for upgrading to a newer version. Please try to build nvcompositor and give it a try. The plugins are open source from r32.5.1. Please download the source code package and try.
