Gst-nvivafilter
Platforms:
  • Jetson AGX Xavier
  • Jetpack 4.5
  • Cuda 10.2
  • IMX274 camera
Hi fellow developers,
I am having difficulties at making custom CUDA implementation. I have succesfully run the below pipeline.
gst-launch-1.0 nvarguscamerasrc !   'video/x-raw(memory:NVMM), width=(int)3840, height=(int)2160, \
  format=(string)NV12, framerate=(fraction)60/1' !   nvivafilter cuda-process=true   customer-lib-name="libnvsample_cudaprocess.so" !   'video/x-raw(memory:NVMM), format=(string)NV12' ! nvvidconv ! nvegltransform ! nveglglessink -e
I wanted to implement custom CUDA pre/post operations on Jetson AGX GPU. I downloaded the nvsample_cudaprocess_src.tbz2 from this post.
GStreamer videocuda and nvivafilter plugins source code - #2 by DaneLLL
I have followed the instructions in the
nvsample_cudaprocess_README.txt (8.1 KB)
file and I made following changes in the
Makefile (5.1 KB)
# # CUDA code generation flags
# ifneq ($(OS_ARCH),armv7l)
# GENCODE_SM10    := -gencode arch=compute_10,code=sm_10
# endif
# GENCODE_SM30    := -gencode arch=compute_30,code=sm_30
# GENCODE_SM32    := -gencode arch=compute_32,code=sm_32
# GENCODE_SM35    := -gencode arch=compute_35,code=sm_35
# GENCODE_SM50    := -gencode arch=compute_50,code=sm_50
# GENCODE_SMXX    := -gencode arch=compute_50,code=compute_50
# GENCODE_SM53    := -gencode arch=compute_53,code=sm_53
# GENCODE_SM62    := -gencode arch=compute_62,code=sm_62
GENCODE_SM72    := -gencode arch=compute_72,code=sm_72
# GENCODE_SM_PTX  := -gencode arch=compute_72,code=compute_72
# ifeq ($(OS_ARCH),armv7l)
# GENCODE_FLAGS   ?= $(GENCODE_SM32)
# else
#GENCODE_FLAGS   ?= $(GENCODE_SM30) $(GENCODE_SM32) $(GENCODE_SM35) $(GENCODE_SM50) $(GENCODE_SM53) $(GENCODE_SM62) $(GENCODE_SM72) $(GENCODE_SMXX) $(GENCODE_SM_PTX)
# endif
# Only Jetson Nano
#GENCODE_FLAGS ?= $(GENCODE_SM53)
# Only Jetson AGX Xavier
GENCODE_FLAGS ?= $(GENCODE_SM72)
When i $ make , i get the following error.
/usr/local/cuda/bin/nvcc -ccbin g++   --shared  -Xcompiler -fPIC  -Xlinker --dynamic-linker=/lib/ld-linux-aarch64.so.1  -gencode arch=compute_72,code=sm_72 -o libnvsample_cudaprocess.so nvsample_cudaprocess.o -L/usr/lib/aarch64-linux-gnu -lEGL -lGLESv2 -L/usr/lib/aarch64-linux-gnu/tegra -lcuda -lrt
/usr/bin/ld: cannot find -lEGL
/usr/bin/ld: cannot find -lGLESv2
collect2: error: ld returned 1 exit status
Makefile:146: recipe for target 'libnvsample_cudaprocess.so' failed
make: *** [libnvsample_cudaprocess.so] Error 1
Any help will be appreciated.
John
Does it work if you don’t make change to Makefile? It should work by default and no modification is required.
Hi DaneLLL,
When i run the make with default Makefile, i get the following error
/usr/local/cuda/bin/nvcc -ccbin g++ -I./  --shared  -Xcompiler -fPIC  -gencode arch=compute_20,code=sm_20 -gencode arch=compute_30,code=sm_30 -gencode arch=compute_32,code=sm_32 -gencode arch=compute_35,code=sm_35 -gencode arch=compute_50,code=sm_50 -gencode arch=compute_50,code=compute_50 -o nvsample_cudaprocess.o -c nvsample_cudaprocess.cu
nvcc fatal   : Unsupported gpu architecture 'compute_20'
Makefile:132: recipe for target 'nvsample_cudaprocess.o' failed
make: *** [nvsample_cudaprocess.o] Error 1
That’s why i changed the Makefile in the first place. On the other hand, something tells me i’m not using the latest nvsample_cudaprocess_src.tbz2. What do you think i should do?
John
Looks like you don’t get correct version. Please download the package:
L4T 32.5 Archive | NVIDIA Developer
L4T Driver Package (BSP) Sources
It contains all open source code.
Hi guys
Hope you are feeling well
I wana use nvivafilter and nvsample for a processing application
In the sample you have wrote a funcation named
static void add_metadata(void ** usrptr)
And in the iva_metadata.h file is defined some metadata varible
typedef struct _location_t Location;
struct _location_t
int x1, y1;
int x2, y2;
typedef struct _bbox_t BBOX;
struct _bbox_t {
unsigned int framecnt;
unsigned int objectcnt;
Location location_list[NUM_LOCATIONS];
Right now,i wanna know how i can use the metadata in the gstreamer Main looper
For example ,how can i get the metadata in main gsteramer loop launcher??
May you help me??
Thank you for your time
Appreciate that
Best regards.
