JenHao
March 31, 2023, 4:07am
1
• Hardware Platform ( GPU)
• DeepStream Version 6.2
• Issue Type( bugs)
I try to add Gst-nvmsgbroker into deepstream_reference_apps/runtime_source_add_delete .
Here is the difference between runtime_source_add_delete(tag 6.2) and my code Diff between origin code
However this code is not working properly.
But if I remove msgbroker from gst_bin_add_many. Everything work fine again. Remove msgbroker
JenHao
March 31, 2023, 4:16am
2
I use RTSP as my source, AMQP as my broker protocol. Below is the command I run my program.
./deepstream-test-rt-src-add-del rtsp://192.168.8.53/live1.sdp 0 filesink 1
I have RabbitMQ install on my local machine and service is running.
● rabbitmq-server.service - RabbitMQ Messaging Server
Loaded: loaded (/lib/systemd/system/rabbitmq-server.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2023-03-30 13:50:09 CST; 22h ago
Main PID: 4079924 (beam.smp)
Status: "Initialized"
Tasks: 163 (limit: 38230)
Memory: 92.9M
CGroup: /system.slice/rabbitmq-server.service
├─4079920 /bin/sh /usr/sbin/rabbitmq-server
├─4079924 /usr/lib/erlang/erts-10.6.4/bin/beam.smp -W w -A 128 -MBas ageffcbf -MHas ageffcbf -MBlmbcs 512 -MHlmbcs 512 -MMmcs 30 -P 10>
├─4080284 erl_child_setup 65536
├─4080382 inet_gethost 4
└─4080383 inet_gethost 4
Below is my config for msgconv and msgbroker. Other is remain the same as runtime_source_add_delete
dstest4_config.yml
# Copyright (c) 2022, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
This file has been truncated. show original
dstest4_msgconv_config.txt
# Copyright (c) 2018-2019, NVIDIA CORPORATION. All rights reserved.
fanzh
March 31, 2023, 7:09am
4
can you share the error log? and nvmsgconv and nvmsgbroker are opensource, you might add logs to check if the data was generated and sent.
JenHao
March 31, 2023, 7:22am
5
Here is the full log. To reproduce this issue, the generated video will not have tile window after add msgbroker into gst_bin_add_many.
log.txt
creating uridecodebin for [rtsp://192.168.8.53/live1.sdp]
Unknown key 'enable-past-frame' for group [tracker]Unknown key 'display-tracking-id' for group [tracker]0:00:02.298625711 2664946 0x55dfc91f1ea0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-nvinference-engine3> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1897> [UID = 4]: deserialize engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed
0:00:02.369860234 2664946 0x55dfc91f1ea0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-nvinference-engine3> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2002> [UID = 4]: deserialize backend context from engine from file :/opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine failed, try rebuild
0:00:02.370909695 2664946 0x55dfc91f1ea0 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<secondary-nvinference-engine3> NvDsInferContext[UID 4]: Info from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1923> [UID = 4]: Trying to create engine from model files
WARNING: [TRT]: CUDA lazy loading is not enabled. Enabling it can significantly reduce device memory usage. See `CUDA_MODULE_LOADING` in https://docs.nvidia.com/cuda/cuda-c-programming-guide/index.html#env-vars
WARNING: ../nvdsinfer/nvdsinfer_model_builder.cpp:1487 Deserialize engine failed because file path: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine open error
WARNING: [TRT]: The implicit batch dimension mode has been deprecated. Please create the network with NetworkDefinitionCreationFlag::kEXPLICIT_BATCH flag whenever possible.
Warning: Flatten layer ignored. TensorRT implicitly flattens input to FullyConnected layers, but in other circumstances this will result in undefined behavior.
0:00:24.973395652 2664946 0x55dfc91f1ea0 WARN nvinfer gstnvinfer.cpp:677:gst_nvinfer_logger:<secondary-nvinference-engine3> NvDsInferContext[UID 4]: Warning from NvDsInferContextImpl::buildModel() <nvdsinfer_context_impl.cpp:1950> [UID = 4]: failed to serialize cude engine to file: /opt/nvidia/deepstream/deepstream-6.2/samples/models/Secondary_VehicleTypes/resnet18.caffemodel_b16_gpu0_int8.engine
JenHao
March 31, 2023, 7:29am
6
I have some progress about this issue. after I add the following setup. The pipeline work again. The key point is "async", FALSE,
g_object_set (G_OBJECT (msgbroker),
"topic", "topicname",
"sync", TRUE, "async", FALSE,
"new-api", 1, NULL);
However, I still want to know is this a bug or not. Doc did not mention this at all.
Blockquote
I do try to debug. However the program seem to hang inside amqp broker protocol library so I have no way to debug.
fanzh
March 31, 2023, 9:31am
7
do you mean your code can work fine now? nvmsgbroker is a subclass of GstBaseSink, so it has async property. please refer to Gstreamer 's explanation async .
can you use nvbroker sample deeptream-test4 to reproduce this issue, you only need to modify the configuration file.
JenHao
April 6, 2023, 2:54am
8
No, when I add nvmsgbroker into gst_element_link_many
, the pipeline break again.
If the source is video file, it work properly. However this example did not support RTSP source originally. I need some time to modify the code.
JenHao
April 6, 2023, 6:48am
9
I modify deepstream-test4 for RTSP souce, following is the difference with origin code.
Diff between origin deepstream-test4
The pipeline did not stuck.
Here is the conf file
I use the following to run app
./deepstream-test4-app dstest4_config.yml --no-display
fanzh
April 6, 2023, 8:42am
10
thanks for your update, you can compare the media pipelines, here is the method of dumping pipeline dump pipeline .
system
Closed
April 20, 2023, 8:43am
11
