Gst_object_unref() gets stuck
Hi!
I have several RTSP streams and APIs that manage my pipeline.
When I change the RTSP count, I recreate my pipeline. I remove the old pipeline in this way:
1 auto status = gst_element_set_state(m_pipeline, GST_STATE_NULL);
2 LOG_INFO("status is {}", status);
3 gst_object_unref(GST_OBJECT(m_pipeline));
4 g_source_remove(m_bus_watch_id);
5 g_main_loop_quit(m_loop);
6 g_main_loop_unref(m_loop);
Sometimes pipeline removal gets stuck on line 3 (gst_object_unref(GST_OBJECT(m_pipeline));). status is always 1.
what could be the problem?
• DeepStream Version
• TensorRT Version
You must wait until the pipeline state is “NULL”. What are states? (gstreamer.freedesktop.org)
Hi @Fiona.Chen , thank you for reply!
After gst_element_set_state I added the following code
GstState state;
gst_element_get_state(pipeline, &state, 0, GST_CLOCK_TIME_NONE);
g_print(state);
I always get state equal to 1 and the line gst_object_unref still gets stuck sometimes.
typedef enum {
  GST_STATE_VOID_PENDING        = 0,
  GST_STATE_NULL                = 1,
  GST_STATE_READY               = 2,
  GST_STATE_PAUSED              = 3,
  GST_STATE_PLAYING             = 4
} GstState;
Where did you do this? Another thread?
I did it in the same thread
1 gst_element_set_state(m_pipeline, GST_STATE_NULL);
2 GstState state;
3 gst_element_get_state(pipeline, &state, 0, GST_CLOCK_TIME_NONE);
4 g_print(state);
5 gst_object_unref(GST_OBJECT(m_pipeline));
6 g_source_remove(m_bus_watch_id);
7 g_main_loop_quit(m_loop);
8 g_main_loop_unref(m_loop);
The controlling should be in another thread. If you ant to control the pipeline, do not create and destroy the pipeline in the main thread. You need a pipeline thread and control the pipeline in another thread.
Hi!
I’ve decided my problem by changed g_main_loop to endless loop while and sent eos message to pipeline.
