All,
I was using the temporal-tradeoff property of the encoder in the past on the TX1 and have not had any issues.
on the TX2 though, it seems it is not taking affect. I have set the value to 4 as seen here:
gst-launch-1.0 \
v4l2src device=/dev/video0 io-mode=2 do-timestamp=true typefind=true ! "video/x-raw, width=1920, height=1080, format=(string)UYVY, framerate=(fraction)60/1" ! queue ! nvvidconv output-buffers=4 ! 'video/x-raw(memory:NVMM), width=1920, height=1080, format=I420, framerate=60/1' ! omxh264enc control-rate=2 bitrate=500000 temporal-tradeoff=4 ! 'video/x-h264, stream-format=(string)byte-stream' ! queue ! mpegtsmux ! udpsink host=224.0.0.2 port=5061 sync=false async=true --gst-debug=*omx*:2
which should drop 2 in 3 frames. So with my 60fps video i should be getting 20fps. Yet i am still getting 60fps. I’ve tried the other settings also (1-3) and they all do not work.
I downloaded the source after seeing a warning stating:
0:00:00.088373571 22938 0x6014a0 WARN omxvideoenc gstomxvideoenc.c:1862:gst_omx_video_enc_set_format:<omxh264enc-omxh264enc0> Error setting temporal_tradeoff 2 : Vendor specific error (0x00000001)
But ironically this error actually relates to the “gst_omx_video_enc_set_quantization_range” function in the code where the error message is actually mislabelled as temporal-tradeoff AND is actually incorrectly returning TRUE when successful when it should be returning a ‘0’ on success. So that is actually a false positive bug.
So the temporal tradeoff is not actually throwing any errors for being set, yet it is still not taking affect.
I’m on 28.2.1
I cross referenced with the xavier release of gst-omx to see if there were any relevant updates but there is not.
