and seek multiple times forward with keys, video always freeze. Do you have any idea how to fix it?
0:00:00.984338412 7180 0x7f940701e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.001626929 7180 0x7f940701e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:01.017908606 7180 0x7f940701e0 WARN v4l2bufferpool gstv4l2bufferpool.c:1474:gst_v4l2_buffer_pool_dqbuf:<nvv4l2decoder0:pool:sink> v4l2 provided buffer that is too big for the memory it was writing into. v4l2 claims 976 bytes used but memory is only 0B. This is probably a driver bug.
0:00:12.466523313 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466545553 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466575657 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466596387 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466625294 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466646440 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466675607 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466696181 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466725452 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466746703 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466777016 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466798214 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466827277 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466848736 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466878580 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466899101 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466928008 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.466949259 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.466980666 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
0:00:12.467002333 6790 0x55b4f0b200 ERROR v4l2bufferpool gstv4l2bufferpool.c:1379:gst_v4l2_buffer_pool_qbuf:<nvv4l2decoder0:pool:src> could not queue a buffer 1
0:00:12.467032229 6790 0x55b4f0b200 ERROR v4l2allocator gstv4l2allocator.c:1358:gst_v4l2_allocator_qbuf:<nvv4l2decoder0:pool:src:allocator> failed queueing buffer 1: Device or resource busy
thanks for answer. Im using latest version “nv-jetson-nano-sd-card-image-r32.2.3” with preinstalled gstreamer 1.14.5. I tried different video files but with same result but with 1080p freezing is not often(but still freeze after 6x fast seek) and with 720p video its rare…
nvidia@nvidia-desktop:~$ nvgstplayer-1.0 --help
Usage:
nvgstplayer-1.0 [OPTION?] Nvidia GStreamer Model Test
Help Options:
-?, --help Show help options
--help-all Show all help options
--help-gst Show GStreamer Options
Application Options:
--version Prints the version of Gstreamer used
-u, --urifile Path of the file containing the URIs
-i, --uri input URI
-e, --elemfile Element(s) (Properties) file
-x, --cxpr Command sequence expression
-n, --loop Number of times to play the media
-c, --audio-track If stream have multiple audio tracks, play stream with given track no
-v, --video-track If stream have multiple video tracks, play stream with given track no
-a, --start Start of the segment in media in seconds
-d, --duration Play duration of the segment in media in seconds
--no-sync Disable AV Sync
--disable-dpms Unconditionally Disable DPMS/ScreenBlanking during operation and re-enable upon exit
--stealth Operate in stealth mode, alive even when no media is playing
--bg Operate in background mode, keyboard input will be entirely ignored
--use-playbin Use Playbin
--no-audio Disable audio
--no-video Disable video
--disable-anative Disable native audio rendering
--disable-vnative Disable native video rendering
--use-buffering Use Buffering
-l, --low-percent Low threshold for buffering to start, in %
-j, --high-percent High threshold for buffering to finish, in %
--loop-forever Play the URI(s) in loop forever
-t, --max-size-time Max. amount of time in the queue (0=automatic)
-y, --max-size-bytes Max. amount of bytes in the queue (0=automatic)
-b, --max-size-buffers Max. amount of buffers in the queue (0=automatic)
--window-x X coordinate for player window (for non overlay rendering)
--window-y Y coordinate for player window (for non overlay rendering)
--window-width Window width (for non overlay rendering)
--window-height Window height (for non overlay rendering)
--disable-fullscreen Play video in non fullscreen mode (for nveglglessink)
-h, --drop-threshold-pct Permittable frames drop percentage, to be used with --stats (only for development purpose)
-k, --image-display-time Image display time in seconds
--show-tags shows tags (metadata), if available
--stats shows stream statistics, if enabled
--stats-file File to dump stream statistics, if enabled
--svd (=) chain for video decoding
--sad (=) chain for audio decoding
--svc (=) chain for video postprocessing
--sac (=) chain for audio postprocessing
--svs (=) chain for video rendering
--sas (=) chain for audio rendering
--shttp (=) chain for http source
--srtsp (=) chain for rtsp source
--sudp (=) chain for udp source
--sfsrc (=) chain for file source
Runtime Commands:
q quit the application
h print help
Up Key, ] goto next track
c restart current track
Down Key, [ goto previous track
spos query for position
sdur query for duration
s<val> seek to <val> position in seconds, eg "s5.120"
v<val> seek to <val> percent of the duration, eg "v54"
f<val> seek by <val> seconds, relative to current position eg "f23.901"
Left Key, < seek backwards by 10 seconds
Right Key, > seek forward by 10 seconds
p pause playback
r start/resume the playback
z stop the playback
i:<val> enter a single URI
thanks. Its much better, seek is much more responsive but its still possible to freeze after 20 quick seeks both directions on 4k video or when i try to seek immediately after video start it freeze almost in 100% cases. I tried on fullhd but it aapears only when im “holding down” right key and it will make somethink like 10 rally fast seeks and then freeze. So its much better but it is still causing me trouble because it will get stuck and player dont quit.
4K decoding on Jetson Nano taks high system loading. Please execute ‘sudo jetson_clocks’ to run in max performance.
And also apply the following patch to nvgstplayer-1.0:
diff --git a/nvgstapps/nvgstplayer-1.0/nvgstplayer.c b/nvgstapps/nvgstplayer-1.0/nvgstplayer.c
index ddd404b..ffb115e 100644
--- a/nvgstapps/nvgstplayer-1.0/nvgstplayer.c
+++ b/nvgstapps/nvgstplayer-1.0/nvgstplayer.c
@@ -1816,6 +1816,10 @@ create_video_pipeline (GstCaps * caps, GstPad * dbin_pad)
NVGST_CRITICAL_MESSAGE ("failed to create video decoder pipe");
goto fail;
+ if (!g_strcmp0(app->svd, NVGST_DEFAULT_VIDEO_DEC)) {
+ g_print("nvv4l2decoder: Set enable-max-performance=TRUE \n");
+ g_object_set(GST_OBJECT (vdec), "enable-max-performance", TRUE, NULL);
if (!gst_bin_add (GST_BIN (bin), vdec)) {
NVGST_CRITICAL_MESSAGE ("failed to add decoder pipe to video_bin");
