GST Plugins Bad 1.16.3
i need the gst pluging WPESRC. I know plugin is in the gst plugins bad package.(>=1.16.x)
Ive tried to compile the gst plugins bad but i am getting an error with openexr.
Blockquote
Making install in openexr
make[2]: Entering directory ‘/home/jetson1/gst_1.16.3/gst-plugins-bad-1.16.3/ext/openexr’
CXX libgstopenexr_la-gstopenexrdec.lo
In file included from /usr/include/c++/11/cstdint:35,
from /usr/include/OpenEXR/ImfFrameBuffer.h:55,
from /usr/include/OpenEXR/ImfRgbaFile.h:51,
from gstopenexrdec.cpp:30:
/usr/include/c++/11/bits/c++0x_warning.h:32:2: error: #error This file requires compiler and library support for the ISO C++ 2011 standard. This support must be enabled with the -std=c++11 or -std=gnu++11 compiler options.
32 | #error This file requires compiler and library support
make[2]: *** [Makefile:922: libgstopenexr_la-gstopenexrdec.lo] Error 1
make[2]: Leaving directory ‘/home/jetson1/gst_1.16.3/gst-plugins-bad-1.16.3/ext/openexr’
make[1]: *** [Makefile:1042: install-recursive] Error 1
make[1]: Leaving directory ‘/home/jetson1/gst_1.16.3/gst-plugins-bad-1.16.3/ext’
make: *** [Makefile:948: install-recursive] Error 1
Blockquote
I know there is a information about this in git. But i am not able to compile the plugin. Can someone help?
Kind regards
Mats Hensel
Try to add
-std=c++11
to your makeffile
Ive modified the line CXXFLAGS and added -std=c++11 but it is not successfull…
CXXFLAGS = -std=c++11
What am I doing wrong?
probably you have to upgrade your compiler
Why do you need to compile the plugin yourself? Not that you shouldn’t be able to but if you just want to use the plugin in an application or CLI pipeline then you don’t need to. You can install them via a package manager if your system has access to one. If you are on a Yocto image without access to a package manager, you should be able to add the Bad Plugins to your build via a recipe.
Good morning, the compiler is up to date. I have installed gcc 11 10 9 and 8.
In the plugins bad packege from the package manager is not the wpe webkit included. That is the reason why need to compile it by my selfe.
I am running ubuntu 20.04.
I really font know how to solve this problem.
Kind regards
Mats
You can check the GStreamer source for dependencies.
ext/openexr/meson.build · 1.16 · GStreamer / gst-plugins-bad · GitLab
You could also try a minimal GStreamer build so you don’t waste time building plugins you won’t need.
Generate a minimal GStreamer build, tailored to your needs (collabora.com)
