I used new RTSP streams in the DeepStream 6.3 pipeline (new streamux ), and everything worked normally. However, when I used two .avi files instead, the pipeline was interrupted after a while, and the following error was displayed:
Warning: gst-resource-error-quark: No Sources found at the input of muxer [videomux] (3): /dvs/git/dirty/git-master_linux/deepstream/sdk/src/gst-plugins/gst-nvmultistream2/gstnvstreammux.cpp(1392): gst_nvstreammux_src_push_loop (): /GstPipeline:pipeline0/GstNvStreamMux:Stream-muxer
Terminated
