I am using Xavier NX (L4T 32.4.3) and trying to build a RTSP server taking frames from the CSI camera.
We are using the gst-rtsp-server library as a base:
This is the gst srcipt we are using:
GST_DEBUG=3 ./test-launch “nvarguscamerasrc ! video/x-raw(memory:NVMM), format=NV12, width=3264, height=2464, framerate=15/1 ! nvvidconv ! video/x-raw(memory:NVMM), format=NV12, width=1920, height=1080, framerate=15/1 ! nvvidconv ! clockoverlay time-format=”%Y/%m/%d %H:%M:%S" ! nvvidconv ! omxh264enc preset-level=3 bitrate=1000000 control-rate=3 ! video/x-h264 ! h264parse ! rtph264pay name=pay0 config-interval=1"
It generally works fine when my RTSP clients are from the same network (within the same router). However, when I try to connect to the server from a remote RTSP clients, I have a very high chance (> 80%) seeing the follow error:
0:01:23.230270747 30967 0x7f880c4590 WARN omxvideoenc gstomxvideoenc.c:1860:gst_omx_video_enc_set_format: Error setting temporal_tradeoff 0 : Vendor specific error (0x00000001)
H264: Profile = 66, Level = 40
0:01:43.179526025 30967 0x55a71e3b70 WARN rtspmedia rtsp-media.c:3272:wait_preroll: failed to preroll pipeline
0:01:43.179633290 30967 0x55a71e3b70 WARN rtspmedia rtsp-media.c:3652:gst_rtsp_media_prepare: failed to preroll pipeline
0:01:43.190663867 30967 0x55a71e3b70 ERROR rtspclient rtsp-client.c:1077:find_media: client 0x7f7c012d10: can’t prepare media
0:01:43.191728265 30967 0x55a71e3b70 ERROR rtspclient rtsp-client.c:2963:handle_describe_request: client 0x7f7c012d10: no media
0:01:43.203113565 30967 0x7f38004800 FIXME default gstutils.c:3981:gst_pad_create_stream_id_internal:nvarguscamerasrc6:src Creating random stream-id, consider implementing a deterministic way of creating a stream-id
It would be great if someone can give me some clue on this. I have been trying to fix this for weeks :(
Cheers,
Max
