DeepStream Version - 7.0
Docker Image - nvcr.io/nvidia/deepstream:7.0-gc-triton-devel
GPU - RTX A6000
NVIDIA GPU Driver - 535.183.01
I’m getting the following error -
sys:1: Warning: g_object_get_is_valid_property: object class 'GstUDPSrc' has no property named 'pt'
Error: gst-resource-error-quark: Could not read from resource. (9): ../gst/rtsp/gstrtspsrc.c(6523): gst_rtsp_src_receive_response (): /GstPipeline:pipeline0/GstBin:source-bin-00/GstDsNvUriSrcBin:uri-decode-bin/GstRTSPSrc:src:
Could not receive message. (System error)
Exiting app
upon doing the following -
pipeline.add(streammux)
for i in range(number_sources):
print("Creating source_bin ",i," \n ")
uri_name=args[i]
if uri_name.find("rtsp://") == 0 :
is_live = True
source_bin=create_source_bin(i, uri_name)
if not source_bin:
sys.stderr.write("Unable to create source bin \n")
pipeline.add(source_bin)
padname="sink_%u" %i
sinkpad= streammux.request_pad_simple(padname)
if not sinkpad:
sys.stderr.write("Unable to create sink pad bin \n")
srcpad=source_bin.get_static_pad("src")
if not srcpad:
sys.stderr.write("Unable to create src pad bin \n")
srcpad.link(sinkpad)
sink = Gst.ElementFactory.make("nvrtspoutsinkbin", "nvrtspoutsinkbin")
sink.set_property('codec', 'h264')
sink.set_property('enc-type', 1)
sink.set_property('rtsp-mount-point', f"/{STREAM_IDS[0]}")
sink.set_property('rtsp-port', int(op_ports[0]))
sink.set_property('bitrate', 4000000)
This error only shows up for certain RTSP streams and for a few it works just fine.
What could be the issue behind this?
