ohet
1
Dear Sir or Madame,
I cannot get gst-shark running on my Jetson TX2. Can anybody help?
I used: GstShark - Getting Started and tried it for Ubuntu 64 bits as well as Raspbian/Raspberry Pi option for the ./autogen.sh script.
However, every time I start a pipeline no traces are being saved. See below. Thanks so much for help,
Thomas
E.g.:
nvidia@tegra-ubuntu:~/remote-controlled-jtx2-robot/gst-shark$ GST_TRACERS=“scheduletime(filter=videotestsrc0)” GST_DEBUG=GST_TRACER:7 gst-launch-1.0 videotestsrc ! identity name=i0 ! queue ! identity name=i1 ! x264enc ! identity name=i2 ! queue ! fakesink
Setting pipeline to PAUSED …
Pipeline is PREROLLING …
Redistribute latency…
Pipeline is PREROLLED …
Setting pipeline to PLAYING …
New clock: GstSystemClock
You might want to check with its author @ ridgerun. That’s their product and they do provide consulting services.
-albertr
Hi Thomas
It may be that the tracers are not being installed in the proper location. Can you try the following configuration?
./autogen.sh --prefix /usr/ --libdir /usr/lib/aarch64-linux-gnu/
make
sudo make install
If that doesn’t work, please provide the output of the following command:
gst-inspect-1.0 /usr/lib/aarch64-linux-gnu/gstreamer-1.0/libgstsharktracers.so
I’ve updated the documentation to include the configuration for the Jetson boards:
https://developer.ridgerun.com/wiki/index.php?title=GstShark_-_Getting_Started#Building_GstShark_Tracers
-Michael
ohet
4
Fantastic. It works now. I can see e.g. interlatency results of my gst pipeline. VERY useful. GstShark - InterLatency tracer
Thanks Michael and the team at RidgeRun for their great support!
