The GstNvArgusCameraSrc element fails with a segmentation fault from when a camera is disconnected (Jetpack 4.6). The segmentation fault is triggered only sometimes.
A camera could be disconnected for different reasons, and being able to catch an error instead of making the app crash is desirable.
I’m running the following pipeline:
nvarguscamerasrc sensor-id=0 ! "video/x-raw(memory:NVMM),width=640,height=480,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=1 ! "video/x-raw(memory:NVMM),width=640,height=480,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=2 ! "video/x-raw(memory:NVMM),width=640,height=480,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=3 ! "video/x-raw(memory:NVMM),width=1640,height=1232,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=4 ! "video/x-raw(memory:NVMM),width=1640,height=1232,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=5 ! "video/x-raw(memory:NVMM),width=640,height=480,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=6 ! "video/x-raw(memory:NVMM),width=640,height=480,framerate=15/1" ! fakesink nvarguscamerasrc sensor-id=7 ! "video/x-raw(memory:NVMM),width=640,height=480,framerate=15/1" ! fakesink
And simulate a serializer disconnection with:
i2ctransfer -f -y 9 w2@0x40 0x0E 0x00
i2ctransfer -f -y 9 w2@0x40 0x0D 0x00
Then argus throws errors and a segfault:
(Argus) Error FileOperationFailed: Failed socket read: Connection reset by peer (in src/rpc/socket/common/SocketUtils.cpp, function readSocket(), line 79)
(Argus) Error FileOperationFailed: Unexpected error in reading socket (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 266)
(Argus) Error FileOperationFailed: Receive worker failure, notifying 1 waiting threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 340)
(Argus) Error InvalidState: Argus client is exiting with 1 outstanding client threads (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadCore(), line 357)
(Argus) Error FileOperationFailed: Receiving thread terminated with error (in src/rpc/socket/client/ClientSocketManager.cpp, function recvThreadWrapper(), line 368)
(Argus) Error FileOperationFailed: Client thread received an error from socket (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 145)
(Argus) Error FileOperationFailed: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
(Argus) Error InvalidState: Receive thread is not running cannot send. (in src/rpc/socket/client/ClientSocketManager.cpp, function send(), line 96)
(Argus) Error InvalidState: (propagating from src/rpc/socket/client/SocketClientDispatch.cpp, function dispatch(), line 91)
CONSUMER: Done Success
CONSUMER: ERROR OCCURRED
ERROR: from element /GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0: DISCONNECTED
Additional debug info:
Argus Error Status
Execution ended after 0:00:08.430645492
Setting pipeline to PAUSED ...
Setting pipeline to READY ...
STOPPING: cancel requests done
STOPPING: wait for idle
GST_ARGUS: Cleaning up
GST_ARGUS: Error
GST_ARGUS: Done Success
Caught SIGSEGV
#0 0x0000007f84ad7d5c in __waitpid (pid=<optimized out>, stat_loc=0x7fe94a2854, options=<optimized out>) at ../sysdeps/unix/sysv/linux/waitpid.c:30
#1 0x0000007f84b132e0 in g_on_error_stack_trace ()
#2 0x000000559029fc3c in ()
#3 0x0000007f8428a000 in ()
I would like to know what to do in this case, or if there’s a patched binary that could help with the problem.
