• Jetson Orin Nano
• DS 7.0.0
• JP 6.0.0 v2
Running d0_avlp_544_960_f32.engine
from github.com/NVIDIA-AI-IOT/deepstream_tao_apps.
Config file, except I am not converting the model to int8.
What could be the troubleshooting steps? Thanks.
• Jetson Orin Nano
• DS 7.0.0
• JP 6.0.0 v2
Internal data stream error
is the default GStreamer error when any element in the pipeline returns something other than GST_FLOW_OK
. To get more information, you should enable GStreamer debug logging: GST_DEBUG=4 gst-launch-1.0 ...
We also have a dedicated wiki page for GStreamer debugging if you need more details:
Feel free to share your logs with GST_DEBUG
enabled, and I’ll check if it’s an error I recognize.
are you testing efficientdet model with nvinfer? what do you mean about “except I am not converting the model to int8”? could you share simplified code and cfg diff? could you share the detailed reproducing steps and logs? Thanks!
Thanks for your responses guys!
gxf_server_logs_2609.txt.gz (122.1 KB)
gzip -d gxf_server_logs_2609.txt.gz
ds_gc_graph.tar.gz (2.3 KB)
I have a DeepStream graph for the Graph Composer, here are the contents of the archive:
graph_config.yaml
- defines the graph in Graph Composer;graph_params.yaml
- overrides the params from graph_config.yaml
;trafficcamnet_config.txt
- config for the 1st detector;lpd_edet_de.txt
- config for the 2nd (cascade/downstream) detector.Is there anything else I could provide?
from the log, the fatal error is “0:03:18.158370353 3836 0xffff68003de0 ERROR egladaption gstegladaptation.c:689:gst_egl_adaptation_choose_config:<video_renderer/video_renderer-sink> Could not find matching framebuffer config”
it is related to egl display. please refer to topic1 and topic2.
Solved, thanks!
