'GstNvStreamMux' object has no attribute 'request_pad_simple'
python deepstream_test_1.py ./sample_720p.h264
Creating Pipeline
Creating Source
Creating H264Parser
Creating Decoder
Is it Integrated GPU? : 0
Creating EGLSink
Playing file ./sample_720p.h264
Adding elements to Pipeline
Linking elements in the Pipeline
File “deepstream_test_1.py”, line 263, in
sys.exit(main(sys.argv))
File “deepstream_test_1.py”, line 225, in main
sinkpad = streammux.request_pad_simple(“sink_0”)
AttributeError: ‘GstNvStreamMux’ object has no attribute ‘request_pad_simple’
This problem should be caused by the inconsistency between the python binding versions of pyds and gstreamer.
Which version of deepstream did you install ?
• DeepStream Version
• TensorRT Version
• The pipeline being used
I reinstall deepstream 6.3, it works fine.
