GstNvStreamMux:src_bin_muxer: surface-gpu-id=0,src_bin_muxer-gpu-id=1
• Hardware Platform (Jetson / GPU) GPU
• DeepStream Version 6.3
• TensorRT Version 8.5
• NVIDIA GPU Driver Version (valid for GPU only) 550.142
When using nvmultiurisrcbin plugin, set gpu_id=1,cudadec-memtype=2, inference engine gpuid is also 1, but the program is not the same gpu error
This problem is related to the version and has been solved in the new version, If you want the pipeline to run on a specific GPU, you can use this environment variable. such as
export CUDA_VISIBLE_DEVICES=3
I see it’s in the documentation
But I found another articleNvMultiurisrcbin doesn’t set gpu-id
is this also a solution, I may need to use different Gpus for different applications in a docker container, can I set export CUDA_VISIBLE_DEVICES=x separately
You can set CUDA_VISIBLE_DEVICES for each application independently, for example CUDA_VISIBLE_DEVICES=2 ./your_application
Does the gpu_id in the configuration file of my nvinfer plugin also match the gpu_id set by CUDA_VISIBLE_DEVICES=2
No need to configure gpu-id
