Gstnvvconv NvBufferLayout_BlockLinear
Hi, I am modifying nvvidconv plugin to run Cuda Kernel on the omem->buf->dmabuf_fd.
I noticed the eglFrame.frameType == CU_EGL_FRAME_TYPE_ARRAY when the buffer is transformed to P010_10LE format. The reason being in lines 405-408:
if (space->enable_blocklinear_output &&
(space->out_pix_fmt == NvBufferColorFormat_NV12 ||
space->out_pix_fmt == NvBufferColorFormat_NV12_10LE))
input_params.layout = NvBufferLayout_BlockLinear;
Is there a particular reason to have blocklinear output? If I set bl-output=false, is there any difference in performance?
Block linear is the format used by VIC.
