Gstream giving issues
Hi I am trying to stream 4k video through gstreamer using
gst-launch-1.0 filesrc location=/home/abhian/Downloads/4k.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! omxh264dec ! nvoverlaysink
However The video is not being displayed.I am assuming that the video is running but displayed judginh from the logs
I am getting following error/logs in terminal
Setting pipeline to PAUSED ...
Pipeline is PREROLLING ...
(gst-launch-1.0:28695): GStreamer-CRITICAL **: 08:58:27.521: gst_caps_is_empty: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:28695): GStreamer-CRITICAL **: 08:58:27.521: gst_caps_truncate: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:28695): GStreamer-CRITICAL **: 08:58:27.521: gst_caps_fixate: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:28695): GStreamer-CRITICAL **: 08:58:27.522: gst_caps_get_structure: assertion 'GST_IS_CAPS (caps)' failed
(gst-launch-1.0:28695): GStreamer-CRITICAL **: 08:58:27.522: gst_structure_get_string: assertion 'structure != NULL' failed
(gst-launch-1.0:28695): GStreamer-CRITICAL **: 08:58:27.522: gst_mini_object_unref: assertion 'mini_object != NULL' failed
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
Allocating new output: 3840x2160 (x 12), ThumbnailMode = 0
OPENMAX: HandleNewStreamFormat: 3605: Send OMX_EventPortSettingsChanged: nFrameWidth = 3840, nFrameHeight = 2160
Pipeline is PREROLLED ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Got EOS from element "pipeline0".
Execution ended after 0:00:24.315970575
Setting pipeline to READY ...
Setting pipeline to NULL ...
Freeing pipeline ...
Probably your TV does not support 4K mode(3840x2160). You may downscale it to 1920x1080 and try again.
gst-launch-1.0 filesrc location=/home/abhian/Downloads/4k.mp4 ! qtdemux name=demux demux.video_0 ! queue ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1920,height=1080' ! nvoverlaysink
Hey. My monitor is 4k@30fps
Please try this video file:
https://jell.yfish.us/media/jellyfish-120-mbps-4k-uhd-h264.mkv
$ gst-launch-1.0 filesrc location= jellyfish-120-mbps-4k-uhd-h264.mkv ! matroskademux ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),width=1920,height=1080' ! nvoverlaysink
$ gst-launch-1.0 filesrc location= jellyfish-120-mbps-4k-uhd-h264.mkv ! matroskademux ! h264parse ! nvv4l2decoder ! nvvidconv ! 'video/x-raw(memory:NVMM),width=3840,height=2160' ! nvoverlaysink
We don’t see any issue in decoding the file.
got errror
ysink
Opening in BLOCKING MODE
ERROR: from element /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0: Could not demultiplex stream.
Additional debug info:
matroska-demux.c(5227): gst_matroska_demux_loop (): /GstPipeline:pipeline0/GstMatroskaDemux:matroskademux0:
got eos but no streams (yet)
ERROR: pipeline doesn't want to preroll.
We don’t observe the error. You may clean gstreamer cache and try again. If it is still present, suggest you re-flash the system.
