(gst-inspect-1.0:12932): GStreamer-WARNING **: 17:21:03.589: Failed to load plugin ‘srt’: srt.so: cannot open shared object file: No such file or directory
Everything is complied like in the PDF, seems to compile fine and install.
all gstreamer plugins work but SRT, seems to also compile fine and install without errors
Everything has to be manually complied because of mod files.
Since it is 1.14.5 by default and we have verified SQA tests on this version, you may consider ot use default on for better stability. For witching to other version, would need forum users to shar experience.
