My TX2 gather picture from many cameras and make IA computation using tensorflow.
When I ran process separatly everything is ok but when I run them simultaneously the process works many minutes and crashed.
The first process that’s stopping is gstreamer with assertion errors.
(XXX:3627): GStreamer-CRITICAL **: gst_allocator_alloc: assertion '((params->align + 1) & params->align) == 0' failed
(XXX:3627): GStreamer-CRITICAL **: gst_memory_map: assertion 'mem != NULL' failed
(XXX:3627): GStreamer-CRITICAL **: gst_allocator_free: assertion 'memory != NULL' failed
I suspect a GPU RAM problem because gstream could works many hours without any problem when it is alone on the board.
With htop the amount of RAM goes up to 70% of the whole RAM.
The first try I have done is to set the parameter “per_process_gpu_memory_fraction” to 0.1 which limits the amount of GPU RAM taken by tensorflow.
It allows me to have a 5 minutes running software (without it can live only many seconds).
The second try I have done is to add a 8Gb swap memory and it has no relevant effect.
I don’t know which direction I must take to investigate.
Is it possible to properly split gpu memory ?
Is it a gstreamer issue ?
Any other idea ?
